Often wise to hang back :wink:
Very light day… I changed the led in my E05 to an XP-L V4 5A2 and built up a beautiful copper P60 shell with XP-L Hi V2 5A3’s and a TA FET+6+1 that I soldered up. I really like the tint and output of the Cree XP-L’s in the 5A2 and 5A3 range. I would love to try out the 5A1 or 5A4, but have never seen them forsale.
Well, actually changed the led in the E05 twice, never drop an XP-G3 in that light! Had the strangest artifacts I have ever seen! Tiny little bit of the center was very bright and the rest was very splotchy. I really thought it would be a good candidate for the XP-G3 5 bin.
Hate it when that happens, swap in a new LED with high hopes and it sucks! :smiley:
Over the weekend I built an old SmallSun ZY-T08 host I picked up from a member here over the summer. No build pics so I’ll just have to tell y’all about it:
Sst-20 DA L3 (5000k)
TA 3ch 22mm driver piggyback on stripped factory driver for contact board
Bistro fw
Blue springs @ tail contact
It’s currently doing 100kcd and 920lm but the sst-20 is just a place holder while I wait on the 28mm 5050 mcpcb for the 5700K SST-40 I have for it.
I built it to run an old matched pair of 30q’s that still have near full capacity but are getting a little old to use in the 2s light they came from so I figured I’d keep them together but in a 2p config for near 6000mAh while being a bit safer with their age and all.
Sucks is an understatement. I have never seen such a bad reflector/led combo! I really did not expect that! I expected the relatively larger die surface and the small smooth reflector to really work well! But the XP-L works very well. It came to me with a Luxeon V2 5000k and I could not stand the 5000k and it just felt odd in the reflector.
Just dropped a CSLPM1.TG & 7A driver into my L21A , First impression, I need more of these emitters!
I’ve ranted at length about how G3s are vile little chips, not even suitable as mules. Hideous yellow off to the sides, bluer out the middle.
Only something like a pebbled TIR lens (or assloads of diffusion film) can clean up the beam.
I agree. The 2mm^2 emitter approaches XPL HI output with much higher luminance, as long as you are ok with the cool color temp. What driver did you use? I’ve been eyeing the constant current FET drivers from convoy. Seems like this type of driver could replace all the FET+ drivers if we can get the right FWs on them.
The only lights that I have found them to work well in are the AAA Tool.
Im using the Manta Ray Driver I think its basically the same as the convoy but has a different resistor.
I was not overly impressed by the XPL Hi leds, and the 1mm white flat is a bit of a one trick pony, but these 2mm^2 seem like a really nice compromise
Unno, I got the Wuben E01 that uses one, and it’s a bit ringy and halo-y, lots of color-bleed all over. Not terrible, but I wouldn’t ooh and aah at the beam. The SOS is a killer, though. :confounded:
Wondering if any optix for triples/quads could be diced up to fit the hole and not need spacers or anything. Might fix a multitude of sins…
Is it any better than the 1mm?
I still have one lying around, as well as a 7,2A driver
Throw is a bit less than the 1mm2, even at 7A (but it is still throwier than a dedomed XP-G2 S4 2B), you get more light and a bigger spot. Tint is similar.
Very nice mod!
Yup, if you have any interest, there’s Oshpark links and BOM info here. I think I also have parts on hand to build one or two if you’re interested.
Interesting, the hotspot of the 1mm combined with a large reflector is a very tiny hotspot.
Result: it throws like a beast, but actually its more fun to show your lightsaber laserbeam pencilbeam then using it.
Its quite useless actually, but fun.
pretty sure it will still out throw an FT03 without to much trouble, but hopefully light up a larger more useful area than the 1mm
I was initially put off by the unusual widescreen profile, but it seems in a reflector it doesn’t effect beam shape much.
Thanks, might try it !
Two mods
1. I changed the LED in a New RRT-01 to 219b sw35 9080.
The process went very smoothly as I did not have to change the reflector and centering ring (required in the Original RRT-01), and I was not asked to separate and lubricate the control ring.
imo the 219b beam in the New RRT-01 is very good with the stock reflector.
I like that the New version uses screws to hold the LED star down. I like the very firm off detente in the New RRT-01. I also like that it has strobe, and that the pocket clip does not ride on the head when unscrewing to change batteries.
imo the New RRT-01 is a nice light, well built, w nice smooth threads. It is a simple mod to replace the stock XP-L w an N219, using the stock MCPCB.
2. I disassembled an Original RRT-01 to lubricate the control ring, because it was too loose and turned on in a clients pocket. I used Nyogel 767a which is very thick and sticky.
The light had been previously modded by Vinh to sw45k. He did not modify the original factory grease, of which there was almost none, and he did not change the reflector.
I installed a kaidomain reflector w a customized centering ring. The beam is now excellent imo.
The dial is now very resistant to unintentional movement, but very smooth and can still be turned with one finger. On a scale of 1-10, the dial resistance is now a 10. When I first got it, the dial resistance was a 1.
After missing the NightWatch Stalker NI40 with the 90.2 Luminus emitter I got to looking at mine and decided to use an older SBT-90 in it for something to do. It was on a square copper MCPCB so I filed that to round and mounted it up with 18 ga leads off the stock driver and bypassed the stock springs with 22ga leads. It pulls ~9A off a Samsung 30T for 2100 or so lumens. As usual, I removed the glass window for a better tint. Not the blazing output of the new emitter, but not at all bad for an emitter that’s been sitting around for over 3 years in my kit box….
Yesterday I switched the metal bodies from two Nitecore TIPs. I got a silver one (Cree XP-G2) on my keychain for some years and am pretty happy with it.
I never switched to the (not as bright) black Nichia TIP I got soon after because the silver one was already scratched.
Since I recently ordered the TIP2, I concluded I don´t need two cold white ones and switched the outer metal plates,
so the more beautiful looking Nichia is in the scratched body, and the black one is now ready to be gifted to my little brother.
