Hi: I think I know what the terms “spill” and “hot spot” are,but not sure about these and what they mean regarding a certain light’s beam type…Zebralight SC600 MKII:
80 degree spill
10 degree hot spot?
I guess it could mean the width of the inner(hot spot)/outer(spill)beam,but would that spec have to have a distance from the wall/surface included?Thanks,HB
Yes the hot spot is the intense concentrated light at the center of a beam profile and the spill is the widest part of the beam.
Distance only matters if they give a diameter for the hotspot and spill. Since they specify each as an angle distance is irrelevant, you can work out the hotspot size at various distances using that divergence angle if you really want, but it’s best to just use that figure as a guide.
Hi: I got thinking last night and thought maybe they were referring to the beam angle shone along the wall perpendicular,which would give a nice beam where one could actually see the angle of the beam,rather than straight on 90 degrees? Thanks,HB
A 45° beam has a 1:1 ratio (beam distance to spot diameter) so at 9’ out the spot would be 9’ diameter. A 10° beam is 2/9ths of 45° so at 9’ out, it will have a 2’ spot.
A rule of thumb is the smaller the reflector diameter, the wider the spot. The shallower the reflector, the wider the spill. Emitter size also matters so an XM-L creates a wider spot than an XP-G.
45° beam won’t give a 1:1 ratio. Also the ratio doesn’t change proportionally to the angle, x2 smaller angle doesn’t mean x2 tighter spot.
It’s close enough. If you want to figure it out exactly, be my guest. ![]()
Oops! You’re right. I didn’t account for the wall to be straight on.
A 10° beam has about a 21” spot at 10’. That’s about a 5.8:1 distance to spot diameter ratio. My C8 has a spot size of roughly 11” at 10’ so I’d guess that’s around 6°.
Sorry for the mess above. S)
Thanks to all who posted!! HB
The exact ratio of beam diameter:distance would be 2*tg(angle/2). For 45° it’s about 0.83.
They mean you are now officially a Flashaholic! Time to get some help! ![]()
