what driver do i need ( i dont understand any of the figures)
i want to use an xre or similar to convert my flashlight to RED
i have found this
http://dx.com/p/cree-xp-e-3w-120lm-650nm-20mm-red-light-board-silver-white-dc-2-0-2-6v-198054
is theis the best cree red that i can get for an beginners build?
what driver will i need to operate this cree off a 18650?
all i understand is the soldering all the ma volts vf imput volt i dont understand or amps etc just need to know what will work with this cree or can somone show me a link to a different cree
i want a good 200 yard beam i have an aspheric lens host
thanks guys help much appreciated
What you need is a 700mA AMC7135 based driver.
What flashlight are you modding? This red LED is on a smaller board if that's what you need.
http://dx.com/p/singfire-cree-xp-e-r2-n4-180lm-red-light-led-emitte-on-16mm-star-258256
Here's a simple driver like Toaster recommended:
http://www.fasttech.com/products/0/10001685/1122403-2-amc7135-led-flashlight-driver-circuit
...but you could push it a little harder with this one...
http://www.fasttech.com/products/0/10001684/1122400-3-amc7135-4-group-25-modes-led-flashlight-driver-c
thanks toaster and keltex
the flashlight i am modding didnt have a name it was just a cheap ebay purchace named ultrafire, it had slide back and fourth zoom with a 30mm aspheric came with a xml t6 and 3 mode driver
as these leds are chep i just ordered an xpg to solder onto it to see if it was that simple and was very supprized when it worked!! but!! when i put a new 18650 battery in it it started to turn blue and has burned out some of the led! i have now soldered it onto a c8/t20 pill that i have no idea what driver it has but it works fine so i now want to turn this host into a red as simply as possibbe as i am a begginner
the pill on this has a 19/20mm driver but i think it will take a 16/17mm and it will take a 20 mm star
keltex, you say i could push it a bit harder with the second driver? does that mean brighter light?
i read that the reds wont work above 700ma??? this i dont understand but was guna go with it anyway what is MA exactly? does the higher mean more power? i need a guide for dummies
many thanks
