If your C8 was quite cheap, it likely already has an XR-E in it. Swap emitters and bob’s yer uncle.
(Single mode suggests a mounted light? The cheapest “Remote Pressure Switch” guts can be swapped into whatever C8 tailcap you happen to have. Worked great when I tried it!)
That’s dodgy, but it could work. Plan on killing an LED or two.
Cree specs limit the Green to 700mA. Your suggestion is going to overdrive the emitter. Not by much, but you’re pushing the you-know-what right out of the gate.
If you’re ordering from FT anyway, why not save yourself some more $$ and order your Green Cree XR-E Emitter from them at the same time? It will cost you ~the same as just the shipping on your eBay auction.
Dimbo this was more help than you know, i greatly appreciate your help. This is my first build so i am not a 100% sure as to what i needed, but i never saw anywhere where the green led can only have 700ma.
Sorry I missed that! I haven’t seen many C8s, and all were gifted away long ago; but IIRC the LED “cup” seemed larger than the P60 size one. Within reason, bigger (even with fitting) would be better for drawing heat away from the LED. But the only way to know is to measure your own C8.
If it’s 16mm, you might like the XP-E in Green, but that’s all FT has for emitters that I can find. The main point for all that was to show you can keep the budget down quite a bit if you try.
