What driver is this?
A month or so ago I ordered some stuff from RMM, one item being a LD-2C 3a I planned on resistor modding for an XP-G2. I get around to working on lights today and pulled the driver out and it is different from the LD-2C I’ve seen in reviews. Is it just soldered together upside down? Am I just an idiot?
This is what I received
This is what is on the website
So what driver is this? Did they change the LD-2C to a different format?
this is the same or like this:
20mm 3A CC 8.4V Single Mode
That is the "new" LD-2C. The last batch of LD-2Cs changed over to the one you see there. It is now very similar to the [also "new"] LD29, although they are slightly different. I will get updated pictures on the website.
Can these be resistor modded? Seems like I can see the resistor between the boards.
Yes, all buck drivers can be resistor modded; however, I'm not sure how far you can go.
I was hoping to get between 4.5-5.5a
I have no experience boosting that particular driver, but based on experience with other buck drivers I think that is a long shot without swapping other components. I know that the prior version would safely to 3.5A-4A, but 5A+ is a huge jump compared to that. The diode looks big enough but what about the inductor and FET? You can try it, and it may work, but be prepared to sacrifice some parts along the way.
