What light currently has the longest run time in a high mode?
I’m thinking the Small Sun ZY-T08 might currently be it?
Edit:
Sorry, I didn’t think it was that vague. Let’s try this.
Given any battery configuration, at any budget, what stock commercially available light has the longest runtime at an output level of higher than 500 lumens.
At what output? Anything with a high capacity battery and an efficient, current-controlled low or sub-lumen mode is going to give you great run times. So it all depends on what output you seek.
That's a low bar. I hate that it handicaps any light that has a higher mode even if it has a 500 lumen mode. It'd be better to seek a light with the best battery life at 500 lumens.
If I were to build your light, I'd get a light that uses 3x 26650 in parallel, with multiple XM-L2 U2 emitters on Noctigons and AR lenses. The driver would be detuned to 1A. With 4500 mAh batteries it should last over half a day on high.
EDIT: I read it again and see that you're okay with modes limiting output to 500 lumens. That's good. So the Fenix recommended below would be too. Maybe the Trustfire TR-S700 too. The TR-S700 should be even better if modded with XM-L2 U2's on Noctigon's, and might be even better with Q bin SST-90's if you can find a place that sells them.
I concur. And it seems you can attach two run-time kits, meaning 4x18650 modules. This review over there, shows that with max extensions, you can get 3h 37m at over 2700lm. So at the medium mode of 450, I think this would get close to 40h run times. I guess this might be the king if there’s no other lights that do more than 3 in parallel at 500 lumens.
This is interesting. It looks like it runs 18650 in 2s for the 7 LEDs, and I guess they made the body and carriers extendible in the same manner as the TK75. At less than half the price, it’s interesting. They don’t seem to say how much the extensions are though.
Well, it certainly wont be as nice as a TK75, I hear its under driven, but you said longest run time at 500 lumens, and with ramping it can get almost exactly on the 500 lumens dot, and running 7 LEDs at a more efficient lower A it should use a bit less power, so should be most “efficient” at it in theory. AFAIK it comes with only 6 battery case, no idea about extending it anymore.
The only ramping light I got was a headlamp ultrafires h2.
It has horrible pwm. So I use it only in high.
And that is why I never bought a ramping light again.
