I can’t seem to find measurements of the Skyray King’s reflector. I understand that the reflector diameter is around 48-52mm, some clarification on that would be great as well. I haven’t found a height/depth figure at all.
Thanks in advance!
Thanks in advance!
overall diameter at widest: 2.007"/50.98mm
overall height at tallest: .715"/18.16mm
reflective surface: .895"/22.73mm wide x .695"/17.65mm deep
emitter opening: .315"/8mm
...but, you have to keep in mind, there are no blueprints or official specs for these things, they build them all different, I think depending on what day of the week it is. Most have the larger 8mm emitter hole, but I have seen some (and own one personally) that has the 'standard' XML hole of 7mm.
Thanks comfy, that’s just what I wanted.
