What is the smallest host that could drive a single 219B effectively at max output (3 to 4A)?
I’m running a dedomed Nichia 519a 3500K R9080 (2800K dedomed) at 5 amps in a Convoy T2 host with a Vapcell H10. Is it a great idea? Probably not. Does it work? Yup. Does it heat up really fast on high? You betya. Is it fun? Hell ya brotha! A 219b at 4 amps runs just great, but I would aim for 3 amps in anything really small personally. The gain from 3-4 is negligable and creates lots of heat. A T2 or T3 size host will work just fine for a 219b at 3amps, just don’t expect long runtimes at high due to heat.
Nice! How long can you get away with running that thing on high? Is that a FET driver or regulated? This looks like it could be a great option with the right battery & driver. Do you know what size driver the T3 takes?
High is not a sustainable output…
T2 does 464 lumens at 30 seconds
Not with stock AA/14500 driver. But what about Convoy 12group driver(17mm)?
the issue is thermal mass, not the driver
the T2 is a 50 gram host… it cannot possibly sustain its maximum output
otoh the Convoy L2 has over 10 times the mass… which allows it to sustain its high output:
runtime and reviews thanks to zeroair
It’s a regulated driver. On high I can run it for around 20-30 seconds before it gets uncomfortably hot, then temp regulation kicks in and it ramps down. It’s a glorious amount of light for that short time though!
not sustainable…
about how many lumens do you think the T2 can sustain, flat regulated like the chart of the L2, without stepping down or overheating?
my guess is the thermally sustainable level for the T2 is about 120 lumens… based on this chart thanks to zeroair
Thank you for this. It sounds like the kind of thing I’m looking for, and it may last a little longer with only 3A running through it. Or maybe I should just make the same as you with one of the 519a emitters I’ve got coming in the post!
I think it’s a little hard to tell from that graph because the T2 was cooled during the test. However the temperature only ever reaches around 26C and the temperature curve is flat around 10 mins in when it is producing 160 lumens, which is the thermal equilibrium for those settings. It’s hard to say what the maximum usable output could be from this host, I imagine it would be a bit higher than 160 lumens if you allowed the host to reach 40C instead (a conservative estimate for pain threshold).
