What is your favourite type of knurling?
NOTICE: poll was accidentally wiped, please re-vote if your choices got cleared! :smiling_face_with_tear:
Pick which ones are your favourite(s) and let me know if I missed anything:
[1] Regular diamond (flat tip) knurling
[2] Regular diamond (sharp tip) knurling
[3] Large diamond knurling
[4] Square knurling
[5] Large square knurling
[6] Rectangular knurling
[7] Linear knurling
[8] Linear (sharp tip) knurling
[9] Diagonal knurling
[10] Spiral / helix knurling
[11] Hexagonal-ish knurling
[12] Holes??
[13] No knurling
Preferred knurling type (max 3 choices)
  • [1] Regular diamond (flat tip)
  • [2] Regular diamond (sharp tip)
  • [3] Large diamond
  • [4] Square
  • [5] Large square
  • [6] Rectangular
  • [7] Linear
  • [8] Linear (sharp tip)
  • [9] Diagonal
  • [10] Spiral / Helix
  • [11] Hexagonal-ish
  • [12] Holes?
  • [13] None
0 voters
Was just curious :slight_smile:
No “don’t really care” option?
Each has advantages and disadvantages…
I like linear, but lean towards the “don’t really care” side.
Well, if you had to design your own light what would you pick?
You must have some preferences…
And a flashlight can’t have all types of knurling at the same time either :woman_shrugging:
My EDC has medium-sized rectangular knurling, which seems to work fine. :grin:
Barehandy? Gloves? Oily/slippery environment?
No knurling but with that chalky HA3 ano might be enough for some. Thick work gloves with lots of oil spray might still require something more.
Sideswitch? Stiff tailswitch? Different grip required for each.
Point being, each person has his own needs, use cases, and opinions.
Worst I ever saw was the little Imalent with display. Slick, smooth, no knurling, teeny switch on the back that you had to press in to turn on/off. Nfw to do that without 2-handing it.
Just goggled it, the LD10. Yikes.
The size of the light and the position of the switches also matter.
Big (heavy) lights will stay in your hands without the need of giving them extra attention/grip.
A Maglite has hardly any knurling, and it doesn’t need much because of its weight.
But a small AAA light with a tail switch might shoot away like a booger if it has no proper knurling.
I like knurling that is effective, but not overly aggressive.
For a 1x21700 flashlight, medium-sized rectangular knurling seems like a good choice.
Here’s my EDC with that type of knurling…
I always liked the knurling on the Arc line of lights, including the AAA .
Arc LS example:
Whatever you call the knurling on the Convoy M21F, I don’t like it. I love the light in spite of that which is a testament to how good the light is.
I would call that the linear / rectangular knurling, just with finer lines.
It’s supposed to be very grippy in the direction that matters most (forward/backward sliding) and less in the rotation/circumferential aspect.
I think this is quite good for a light with a tail switch. However, when the light has a power switch on the side, rotation definitely matters, and I agree with you it is a bad choice on that specific light.
Very nice flat top diamond knurling, maglite style.
I really like this as well :slight_smile:
It’s not actually sharp, but it reminds me too much of holding onto heat sink fins. I also think it looks worse visually than many of the options in the poll
I edited the poll label for #6 and now it jumped to the end, anyone know how I can make it keep its original order?
Regular diamond with sharp tip.
It’s the only small-scale texture that does not slip when paired with a slippery finish (like clear anodizing), or when held by sweaty hands. All of the others slip in my experience, especially when pressing on a very firm tail clicky.
I don’t like large-scale textures as much–too much extra material+weight. I also dislike the linear ones because they are very good at visibly trapping grime.
Crude, but…
Edit what should be #1 to stick that at the end.
Edit what should be #2 to stick that at the end.
Edit what should be #N to stick that at the end.
It just “re-sorts” each item in turn.
Well apparently editing the names just cleared all the votes in the poll :sob:
Sorry everyone…
Please vote again if you see this :frowning:
As of the latest votes it was approximately 1/3 for diamond knurling (flat and sharp tip) and 1/4 for square knurling, remaining votes mixed.
The images and their text don’t match the poll options.
Fixed, thank you :face_with_open_eyes_and_hand_over_mouth:
Jeez what a mess I have made lol
