If you just want to check voltages you don’t need to spend too much. A cheap meter showing voltage to 2 decimal place is enough resolution. Does it have to be from RS? Company account? You could get a nice Fluke or Agilent.
From a modding point of view, something that can measure current up to 10A is good, continuity beep (some of the cheaper models don’t have this but it’s useful) and diode test. If you get a cheap meter you can make your own leads for tail cap measurements as the leads supplied are generally unsuitable for accurate current measurements unless you get a really good meter.
I bought an inexpensive one from B & Q - less than £10. Runs on a 9v battery, digital display, measures volts, amps, ohms, continuity and so on. If you just want to check cell voltages it’s just the job.
For current measurement I use solid copper house wiring 2.5 or better mm2 It is a bit awkward to handle but once you get it bent the way you want, it tends to stay put. The stuff that 13A sockets are wired up with is fine (2.5mm2)and you only need a foot or so of it. Just double up the ends so they'll stay in the meter sockets and bare a bit at the other end for making contact with cell ends. You should be able to get an offcut from a sparkie or at work.
Keep current measuring leads as short as is practical.
Go for a Tektronix Agilent or Fluke within your budget, they won't be cheap but they should last you a lifetime. You really just need current, voltage and occasionally resistance. Continuity check is very nice to have. The sparkies round here seem to be getting Tektronix meters from their employers just now - it used to be all Flukes. Or if your employer disposes of them when they are out of calibration (As mine does)- see if they'll sell or give you a used one. You can get them recalibrated for not to too much. I'm assuming since there is an RS account involved, your employer does stuff with electricity.
As a voltmeter the 7k device is not that good, but you will be hard pressed to find anything better for small currents. The 7k meter has a resolution of 0.0000000000000001A (0.0000000001uA or 0.0001pA) at the most sensitive range in both AC and DC current.
