What non-white flashlights do you have?
Convoy S2+ with Nichia NVSU0233B about 2W of 365nm
Convoy S3 with Lite-On 365nm @1050mA
both with zwb2 filter
Elekin UC17 modded with MELD white +RGB+UV
modded the board, so the XPL is on DTP and the RGB+UV board glued on top
Convoy M1 “CYANIDE”
Four Rebel cyan emitters
I’ve taken this light for walks through the paths in the ravine and the cyan is actually a quite pleasant tint for green spaces. It also clearly illuminates for a an easy visual.
I just got a couple of these amber triple P60 dropins from Kaidomain to use in my neglected Solarforce lights.
KDLITKER P6-TRI Triple Cree XP-E2 Amber 590nm 800 Lumens 3V - 9V 5-Mode P60 Drop-in (Dia. 26.5mm)
Plenty bright in a 1-cell Solarforce host, and fine in the 2-cell host (Solarforce L2).
I have multiple red lights and IR lights I’ve built for hunting. Probably 15 total.
Bob has this one
New meaning to Black Flat.
Hmm, forgot about these, but I do have some more flashlights-of-color (they don’t like being called non-white) in red‘n’green, a few HS-802s.
Nice deep reflectors, pushes the spill out farther so the ground in front of you doesn’t get so washed-out. Stick in a small emitter (XP-E2, ferinstance) and you get a nice small tight bright hotspot to boot.
Convoy C8 - 5050 Epileds UV 400nm (fluorescent powdercoated host by 3Tronics almost glows when on)
Convoy C8 - 3535 3rd-LG UV 365nm (LD2 driver + swapped reflector: quite a thrower)
Convoy S2+ - 3535 Nichia UV 365nm
SK68 - 3535 led from old S2 365nm
The rest of my UV lights got into a GAW
Thorfire VG10 - 5050 Epileds 450nm blue led (gives me the creeps every time I fire it up)
Nitecore EA11 - Cree XM-L2 U2 + secundary red led
