I have this busted up 3 x AAA defiant someone gave me. I've been playing around with reserecting it into something useful, but I need some help identifying this switch.
I'm pretty sure it's an Eswitch, but then again it might be some kind of miniature low power clicky switch.
I have some of those, but might as well use this one if it will do the same job. Actually, it has a satisfying little click when you press it. Some momentary switches are too sensitive to the touch.
Hey Ouchy. Best way to make sure is to test it. Check it for continuity. Click it and then recheck. If there is not continuity on both tests, it’s momentary.
To confirm, check for continuity while the button pressed. Then, it should have continuity.
That makes sense. I just remembered that light you have there. If I recall correctly, its a multi-color jobby with one or two blinky modes. I remember mine had a terrible switch that was quite unreliable. There is probably an MCU (COB?) under that white blob. Pretty certain that’s a momentary switch with oxidized contacts. A bunch of clicks may scrap of the oxidation and get it working again.
EDIT: Something about this light that was nagging at me. Dug through my parts boxes and found it. Definitely momentary switch, but the switch works great. When I tore it apart, I found that the problem was a ground pin (tin wire sticking out of the bottom of the driver) did not have a good connection to the host. Fixed that and it now works very reliably. Modes are White, Red, Green, Flashing Red. If you click fast past White, Red makes a nice getting around the house at night light.
