what throws better?
What throws better,a cold Xpg or a cold dedomed XML?Both from cheap lights with stock Al stars?
My two bobs worth is the dedomed XML. Of course how hard there driven, reflectors etc all come into play.
aspheric or reflector? both at the same current levels?
I say xp-g, for a reflector based light., although an xm-l might be able to muscle it’s way to the same throw distance because of the extra lumens.
If you have max-lux in mind as "throw", then as quick&rough estimation they're equal, because they have about the same luminance at the same current. Max-lux is determined by luminance if everything else (reflector, front lens) is equal.
I measured an XP-G2 with dome with 12.5cd/mm² @350mA. The XP-G performs at about 88%, that is, 11cd/mm². And an XM-L without dome @350mA delivered about 10.5 cd/mm². These numbers are not exact, but I believe they're fine as first guess.
Hey people’s just wanted to say hello. I was wondering are we allowed to barter trade or sell stuff I have 18650 bats ALOT. I get em from work when the battery packs break or wear out because of over use and won’t connect to charger or when someone gets the circuit board wet with oil or brake clean and bat are all checked with meter and charged and holding charge for days. Please if not allowed then I can remove and never do again.thanks and like I said hello nice to meet u all.
Well, I can say for sure it wouldn’t be encouraged in someone else’s thread that has nothing to do with what you want to sell.
