What Would You Do With A 30mm... ?
I have a couple of 30 mm drivers I got from Lexel 3 years ago. :person_facepalming: FET & 7135*8 +1, attiny85.
I gave away the Supfires I was going to use them in before I got around to modding them.
Every time I open the parts box with drivers in it I see them and think to myself that I should use them. What do they fit these days? Any thoughts what to do, make?
They have room for a lot of sanding down a few mm
Actually I have 3 :person_facepalming:
30 mm copper pipe, 8x 2700 K mule, 26650 battery.
Use the 12x mule if you are going 26650 and 30mm
Might be good for a D cell Mag mod.
I like the way Sammy and contactr are thinking though.
I guess the whole e-switch situation needs to be considered.
Na, just 2 modes, ON and OFF.
Then save the driver for something else and just connect right to battery :slight_smile:
I like the 30mm mule idea. I wold need to research pipe sizes though. In the US we are still bleesed or cursed with inches, not millimeters and nominal sizes bear little to reality.
1” type M has an ID of about 26.8mm, so a little reduction of driver diameter would be needed. Then it becomes a question of whether or not a 26650 will fit. Maybe some would; have to look at that. The next larger std copper pipe runs 32 to 33 ID depending on the type of copper. US pipe sizes relate to the ID but that varies depending on type M, L or K. The OD is the same at 1-1/8 so all three types can use the same couplers and other fittings.
I think in the EU they size pipe by the OD, and also have different wakk thicknesses and end up having different ID’s as well.
Plumbing can be very confusing.
But it is an idea… I had forgotten about that 12x 3535 board at mtn-e.
Keep the thoughts coming.
Maybe use a 1” body and taper up a size at the driver/head.
If you go 12x 3535 then I would probably want to run a 30T instead of any 26650 that I know of. Even 219Bs would want 30A in BLF-mode
