What's better in the tail cap - double spring, or wire bypass?
I’ve got an Astrolux S41. Its tail cap came stock with double springs (two concentric springs one inside the other, presumably to give a parallel current path).
I’m thinking it might be better to remove the inner spring and just do a traditional spring bypass? It seems that while two springs are no doubt better than one, there’s no way two steel springs can equal a spring plus a copper wire.
I figured at least 20ga wire for the bypass, since it is a FET quad light - would you agree?
Spring bypass through pcb directly to the switch leg.
I always thought the double spring was more about keeping the battery from bouncing around and damaging internals. I think I’d just bypass the outer spring and let the inner spring keep my battery from acting like the shot in a deadblow hammer.
just my 2 cents
Simply put, 2 springs can handle twice the current of 1 spring.
S41 (like most lights) only has a single driver spring though.
Give the wire a high pitched spring shape inside the spring, soldering just both ends.
Of course, the thicker the wire the lower its resistance, but since you're barely going to need an inch or so, it's not that much of a deal. An inch of 24AWG wire drops 21.986mV when 10A of current goes through, AWG22 drops 13.827mV and AWG20, 8.696mV. As you can see, not that much of a difference at such rate. In practice, the delta would probably be slightly smaller (soldered ends).
Cheers ^:)
Already did spring bypass on the driver side. :+1:
Small brass pill soldered to the driver?
I just tested in a modded tn36 that I have two of. One carrier is double spring and one is wired. I used same light and same 30qs. I lost 190 lumens with the double spring.
So my vote goes to wire is better. The tn36vn does 13000 lumens.
Just to have it mentioned: in case of a short, steel springs will collaps and break the circuit, bypasses will allow the full amps. So make it a well carried out mod that will not fail.
Wire for sure!
I have 2 of the same lights(S41S) and I switched the tailcaps (one stock, one bypassed). wire bypass with 22AW was clearly brighter.
Hmmm…
So i have some more work to do…
:slight_smile:
I did test bronze alloy double springs
At 5A 180mV drop, bypassed with 0.25mm2 17.5mV
Even a really thin copper wire is way better than the spring
That’s quite a difference… :open_mouth:
Can anyone provide this noob with a pic how a spring bypass looks? Cheers.
Good safety tip.
It’s also why I don’t use “wire outside the spring” bypass for the driver spring.
http://laserfreak.net/forum/download/file.php?id=32187&mode=view :wink:
(nothing to see in that link though…)
