What's happening to my Convoy S2+ ?
Hi I have a modded convoy s2+ @6A.
when it’s switched on, off, and on again, or I change modes, it seems to flicker like strobe for some few seconds, stays on the same mode, then the light kinda fades away like the Battery is low.
When I change batteries it’s ok , but once off and on again it does it again.
Protection trip?.
But it’s on a 10a battery.
See link;
Best 18650 Battery For Flashlight 3500mAh (Free Battery Case) Orbtronic (link is external)
Thanks.
I have fought with this a time or 2, some lights seem worse than others. Mine have always been either the driver or switch retaining ring are not tight enough to make a great connection. In any case it is usually a weak BAT- connection for me.
What does “Modded” mean? What’s in this sucker? It’s very possible to pull over 10amps and trip the protection
Modified light lol,- the batteries are protected but state safe for 10A.
Light is only at 6A.
Thanks.
Thanks!,…
So it’s an LD-2 driver or something? If so, probably not the batteries. Matt could be right, I don’t know much about that driver (haven’t used it).
Thanks could be driver.
well this will be investigated in the coming days.
Surely it’s not the 10A protected batteries right?.
Orbtronic 3500.
Thanks
We need to know exactly how it was modded. What driver? Do you actually measure it doing 6A? Information man! :smiley:
LOL, reminds me of a line from “Used Cars”: “I know where the…”
J&H
I bolded part of your post for relevance. The problem “could be” any part of your light as far as we know. As other members have mentioned - please post detailed information about your custom flashlight.
  • Source of flashlight
  • Driver
  • LED
  • Battery (you’ve already posted this)
  • mods (bypassed springs, sanding, new switch, adding triples, etc)
