Whats similar to an SC60W ?
I thought I should try here, CFM didnt get results…
I need a light as follows :
  • Side switched (though that can change if it has to, Ill have to mount it different…)
  • 18650 based
  • 180-300 real lumens….
  • at least 2 modes
I have an SC60W that I used to make a magnetic/clamp snake light.
I love the tint and output. H1 is 2 hours, H2 is 4, Which I use most of the time…
I also like the side switch and UI, and I used a modified tailcap to mount it in my application.
I want to make a couple more of these ‘magnetic snake lights’ and want to hold the cost down….
W/O the light I am about $40 into each light …Adding a $60 ZL makes it hurt a bit more, though
it wasn’t such a hit when I was prototyping these…
What lights fit my criteria…?
nada?
Not sure if the you can sacrifice not having a side-switch but I love my UF-H6.
  • Side switched (No)
  • 18650 based (Yes)
  • 180-300 real lumens…. (Easily, probably on Med)
  • at least 2 modes (4 modes Low-Med-High-Turbo)
UltraFire UF-T50 , if tint is not important.You can get it here
mhh… wait….
Olight s20 !
Sideswitch,
18650,
>300 lumens,
4 modes,
magnet in the tail,
under 40 $,
wel known brand.
you are welcome! :smiley:
I have the S10 and love it ordered the S20 as well hopefully it will get here today!
thanks guys for the starting point, now I can investigate some leads!
I appreciate it as the flashlight world is pretty huge
Tony
Shadow GF1
  • side switch
  • 18650
  • 4-modes
  • output should be above 300lm
linky
http://www.fancyflashlights.com/goods.php?id=488
Please let us know your thoughts on the light. It looks awesome.
Okay, I don’t have $35 to impulsively blow on flashlights, but I just bought the S20. If you choose to do so, be sure to use coupon code here to save $1. Free shipping too.
Question: Someone please confirm it will be worth the beatdown I get from my better half! (J/K BTW!)
I have both the s10 and s20. paid more than that though. :~ Like them both. The magnet is definitely strong enough. just remember to unscrew the tailcap a 1/4 turn to guard against turning on in your pocket.
