Whats the difference (if any) between these 2 King Kongs? And another battery question or two.
Hi, sorry about all the questions. But I was looking into some batteries and found these two which to me appear to be the same thing, except one is slightly cheaper… same seller…both KK, both 4000mah.
Are these the same?
http://www.cnqualitygoods.com/goods.php?id=1871
and
http://www.cnqualitygoods.com/goods.php?id=1836
While on the subject of 26650’s, are the KKs OK, or would I better off with say these? … Loading...
Q 2 Can this torch, which I already have in my possession, handle 2 of the above 26650’s above (or any 2 for that matter)? I bought it with an extension tube, just in case I decided to use it as it was only a dollar or so, but now Im unsure if I should ‘smoke’ test it.
http://www.cnqualitygoods.com/goods.php?id=1976
Q 3 Also, Im looking at adding in some 18650s to my order as Im going to snaggle myself a Solarforce 1100, or maybe the 2200. So, again, whats the difference between these two batteries and would they be suitable? Both are Panasonic cells (one is Keeppower wrapped), one is Panasonic it appears. There is a third battery I have linked, as it has an ‘A’ the 18650, what is the difference between A and B, and I think Ive seen E.
Loading... Panasonic 18650 34000mah
Loading... Panasonic (KP wrapped) 34000mah
Loading... 18650’A’ Panasonic, 3100
Cheers and thankyou for the advice so far.
This one has a protection circuit.
The other King Kong you linked is ‘unprotected’
http://www.cnqualitygoods.com/goods.php?id=1890
This is simply the King Kong 26650 with a KeepPower Label and Keeppower’s particular protection circuit.
_
The 18650s, The Keeppower wrapped panasonic NCR18650B 3400mAh should be almost identical to the EVVA.
http://www.cnqualitygoods.com/goods.php?id=1495
This one is an NCR18650A, 3100mAh capacity.
Minor differences between resistance, and the 300mAh capacity difference are the only differences I’m aware of.
Argh, how did I not see that?
Thanks.
No ideas on the torch frying with a pair of 26650’s?
My guess is it would fry, the 26650 extension is meant for the DIY 26650 Host on CNQG afaik.
Relatively blind guess though. I can’t recall reading about anyone trying it yet.
I think you might be right. I need to ge my head around the series, parallel idea. I was thinking in line (series) they would be mostly extra storage same voltage, when its the other way round. Parallel is extra capacity same voltage (well,provided cells are the same), series is higher voltage and drives everything harder.
Your blind guess is better than mine. Cheers for that. I dont want to be the one to test it. I dont have enough lights (yet) to just toast one for giggles.
