Tell us your best flashlight and let us know the brand,model, lumen, mode,runtime and other features of the flashlights. And you have the chance to get a gift.
brand:
model:
lumen:
mode:
runtime:
other features:
Convoy S3 with lowest 1.5mA moonlight mode runtime is approximately 2260 hours or 94 days using 3400mAh batteries. Highest mode is 3A, runtime is obviously approximately 1hr on that one.
brand: Sunwayman
model: V11R
lumen: 500
mode: infinitely variable
runtime: forever on low
other features: beautiful construction. Smooth magnetic infinitely variable brightness. the lowest of the low is superb for when you really don’t need too much
Zebralight Sc62w. 930Lm on high, 0.01Lm in lowest mode with 5,5 months runtime. Feels great in the hand and almost perfect UI.
Very bright for it size and very nice tint.
is this factory moon mode or you did some modifications to get it so low? did you measure the actual current or this is manufacturer specified runtime of 5.5mo on moon ?
Brand: Olight
Model: S15 Baton
Lumen: 0.5, 7, 70, 280
Modes: moon, low, mid, high + hidden strobe
Runtime: 15 days, 32h, 4h, 45m (with a 600mAh 14500)
Other features: can be used with 1x14500, 1xAA, 2xAA and even 3xAA (if you’re crazy enough :D), tailcap magnet, great UI.
My best flashlight is a headlamp
Crelant ch10
2 adjustable modes with strobe
About 400 lumins for 1 hour on high
Very waterproof
Light and compact
My most used light
brand: Zebralight
model: SC62w
lumen: 930 lumens
mode: various. 0.01 lumens low moonlight
runtime: max 5.5 months at moonlight or 2 hours at max 930 lumens (however includes output decreasing due to thermal sensor chip).
other features: side electronic switch, great UI, potted electronics, integrated clip, all modes current-controlled, neutral XML2 emitter with great tint, thermal sensor chip, low voltage protection, one-piece body and head with great thermal properties. Probably the best unmodded 18650 EDC light available today.
brand: Zebralight
model: H52w
lumen: 280 lm on high on AA (500 lm for 1st minute on 14500) or 0.01 lm on low
mode: 3 main modes (plus submodes, plus strobe/beacon if desired)
runtime: 0.9 hrs to 3 months
other features:
- great EDC light
- good balance between spill (80 degree spill) and throw (12 degree hot spot)
- good tint (neutral white)
- battery capacity indicator
- recessed button makes it impossible to turn on accidentally in a pocket
- 90 degree offset reflector and rotating detachable clip makes it convenient to attach the light in almost any position on clothing and rotate the light to point at a specific object in order to work hands-free
soft detachable headband can be carried in a back pocket of pants
CNQualityGoods Zooming 1x18650 generic host with the Ahorton 27.2 mm. aspheric lens, BLF17DD driver and dedomed XM-L2 S6 7D3 LED.
Click the image for the thread. Post #9 and following.
The larger bluish spot is that of a similar light with a cool white XM-L not dedomed.
brands:
CNQualitygoods, Ahorton, BLF (kit from M. E.), Cree, Noctigon
model:
generic zoomy host
lumen:
600 or maybe 1000
I measure 3.85 A with a fully charged IMR cell. My leads have considerable resistance.
I had this XML-2 marked S5 7d, but it might be T5 7d. I guess 75% out the front with this lens.
mode:
Six modes, with no flashing modes
runtime:
An hour to a fortnight, depending on mode
other features:
Bezel ring filed to fit lens and not to block light, very good build for a cheap zoomy, zooms from unusual throw for a pocketable light to wide uniform flood, no spill and very warm white allows more light to be used without disturbing others
