Where Can I Buy a 219C 5000K 90+ CRI? (Or any high-CRI 5000k LED)
I’m looking to build a new EDC from a ToolVN host. I want an LED that is 5000-5500K and is high CRI (that is not an LH351D). I know Acebeam uses 219C 5000K 90+ CRI, but I can’t find out where to buy them.
I’ve seen that LED in person before, but it doesn’t have a super high output and it may be a bit too rosy.
Where are you located and how many do you need? I may have a few spares lying around.
In my experience the 5000K 219C 90cri is very green. I like my 5700K 90CRI 219C a lot better, if you can tolerate the cooler color temperature.
May I ask: why not the LH351D? My dogfarts are far more pleasant than my 5000K 219Cs and I didn’t even slice them.
I agree that the LH351D dogfart has a better tint.
219C is not as floody, which is one advantage depending on intended use.
I mixed 4000K and 5000K 219C in my M43 and I got a fabulous slightly rosy neutral white 4500K tint. 219B tint with 219C output. A no compromise option if used in multi emitter setup.
I second the “why not the LH351D”?
A sliced 5000k LH351D is one of my favorites!
I’ve had some very good and some not so great 219Cs.
I plan to do the exact same 4000k / 5000k 219C mix in a Astrolux S43s.
Right after I replace the 219Cs in my FW3C with sliced LH351Ds. Slicing not only reduces DUV, it increases throw.
FB
Is the dogfarts (S6 bin right?) really that much less green? I read some forum posts that said it was pretty green, but that could have been a different bin. Also, what does slicing do and is it difficult to do? How are the beams in comparison between the LH351D and the 219C?
Thanks
