I’m just curious as I have a few laying around. Cupboard? In your torches just sitting on a shelf waiting to be used? Fridge?
I recently saw someone with a photo of their spare 18650’s in a bag in their fridge…is cooler temperatures better for them or something?
I don’t know if it’s the right place as I’m new to all this but I keep my charged Li ion cells in torches and my spares and other types, NiMH in battery boxes in a large Tupperware type sealed box.
I’d be interested to find out correct storage as well.
Clear plastic case with compartments and a hinged snap down lid. Bought in the sporting goods section of Walmart, think it’s a tackle box for fishing lures. Only $5 or $6 and well made. Almost forgot, when I want to carry some 18650s I use a tall prescription pill bottle, holds 8 pretty tight stacked 4 + 4.
I store mine at a little below room temperature in the lower floor of the house in similar boxes as above. As long as they are not stored in a elevated temperature (above room temp) they should be fine. If you need them to last as long as possible you can keep them in a refrigerator. Do not take li-ions directly out of the frig and begin to charge the batteries. You can use them directly out of the frig, just don’t charge them out of the frig. Give them a little time to come up in temp before charging. Charging at freezing temps can cause plating of metallic lithium on the anode, which is irreversible. The battery then becomes more vulnerable to failures.
+2 Only look in the crafts section as they sell the same thing there only cheaper! I like the look of that shell case as well though... I've got a lot of fresh LT pulls on hand now and that would definitely help me organize! I used different colored shrink overwrap from FT to keep them sorted by which cell they were pulled from so I can keep track of the age...
I store mine in cartoon boxes, in balcony (so not inside but not outside). I mean about my Li-ion rechargeable Panasonic NCR18650B (3.4000 mAh). In order to prevent aging, Li-ion battery must be stored at about 14 Celsius degrees and approx 40% charged. You also can keep it in your flashlights, even in condition of parasitic drain, because this drain is generally lower than self discharge. Don't keep it in fridge! 14 Celsius degrees and about 40% charged.
