Where is the problem? AMC7135*8 driver + XM-L2 on copper PCB only consumes ~1.8A current
This is my third attempt to create a powerful XM-L2 flashlight, but the result is the same. Recently I received already third on Noctigon XM16 MCPCB munted XM-L2 LED and Nanjg 105c driver wih 8x7135 from http://intl-outdoor.com
I put them all together and it draws up to 2A max from freshly charged 18650 battery.
The same result on the first two…
I tested it with 2 years old Soshine 18650 battery and same age Panasonic NCR18650 unprotected battery, but the results was similar…
Maybe I should buy a some new battery?
Or maybe the fault is in somewhere else?
Maybe someone has encountered a similar problem?
No, but one question comes to mind... are you sure its only drawing 2A?
maybe your test leads of your DMM are too thin...
do you have any other light that draws more than 2A?
Maybe you need a better Multimeter, or thicker leads. When was the last time you checked the battery in your multimeter?
Let’s try with better wires for your amperemeter, thin and long wires make big voltage drop and current fall down.
Thank you guys!
Just tried to add a shorter and thicker cords to my multimeter - and it really helped!
I did not come to mind that the fault could be so simple!
Really thank you!
