Cheers!
Is there a cheap source for Anduril drivers that ship to the EU?
Why are there so few / no sources, does anduril need such special components?
Thanks!
Cheers!
Thanks!
Arenāt they married to the hardware? Eg, button lights, aux lights, etc.?
Buttons gotta be either integrated on the driver board itself, or on a satellite board, etc., too. Ie, married to the hardware/host.
Cheap means it should be made in China and in high quantity. And what size? There is no universal shape and diameter. Most of lights have integrated charger too. It just not not worth itā¦
Iām assuming you mean Anduril 1 or 2 and the forum software made that look like āone halfā in the title.
Sadly not a lot of good sources for cheap Anduril drivers. I donāt know about shipping to the EU, but try these:
Good point.
TS11ās driver is $4 only
Thanks for that link! I hadnāt checked there in quite some time. Last time I emailed them they said they didnāt have any TS10 drivers for sale, but I just ordered some from the link.
FYI to everyone, the TS11 (and probably TS12) drivers are T shaped and difficult to fit into most hosts. The TS10 driver is made to be used with a signal tube, but can be modified for use with an eswitch instead.
I had no Idea Wurkkos was selling components like drivers!
I canāt find it on their website, is that even listed anywhere?
Thank you very much!
@James_C Yes, I wrote ā1 / 2ā without the spaces and the Forum-AI-Overlord changed it.
You can also buy Hankās drivers as a special order item (or from Jackson but thatās from the US), depending on what you need (linear+FET, lumeX1 boost)
Do you have a link to the Lume X1 driver on JLHawaiiās website, I canāt find anything there - itās a total unorganized mess.
Searching ālumeā found everything, ālume x1ā pulled up this blog
Yeah itās hard to navigate. Here is the link to all of the Hanklight drivers on that site, just choose the right driver for your uses
Just FYI they are significantly marked up from what Hank sells them for.
