Hi, Can anybody point me where I can buy plastic centering “things” to center XM-L and XP-G2 in P60 pill?
Thanks, Mike
I think intl-outdoor had some, Ill go see if I can find them.
edit: Cant find them, must have been somewhere else. I saw them about 2 days ago.
and cnq, kai-domain, fasttech
Yep, Int'l Outdoor and KD sells them. I think I saw them on FastTech too. Yep, here they are at FastTech. They also have "paper' insulation gaskets.
Here's I/O's centering gaskets, and here's the basic insulators.
-Garry
i couldn’t make up my mind a couple weeks ago so I just ordered some of everything, from everywhere
7mm opening / 16mm diameter / 0.5mm thickness / insulation & location function
XM-L is 5mm, so it won’t fit, isn’t it?
I already found them.
What about XP-G2? They are 3.45x3.45
Insulatnion does not matter I want to center them.
Mike
Which ones are you looking at? Yeah, 7mm would give a little slop.
-Garry
Ok, those: http://www.intl-outdoor.com/cree-xml-led-reflector-positioning-gasket-10-pcs-p-457.html gonna do the trick.
Ok, for XM-L found, what about XP-G2?
Mike
7mm opening / 16mm diameter / 0.5mm thickness / insulation & location function XM-L is 5mm, so it won’t fit, isn’t it? I already found them. What about XP-G2? They are 3.45x3.45 Insulatnion does not matter I want to center them. Mike
Here you go:
Been asking the same question a while ago. Glad there are more options, but I still hope I’ll find one with a full circle and square hole for XM-L.
Fancyflashlights has these and they work. They're the same one's that JMac linked, but FF will ship for free.
Don't use the white ones at KD and IO. Those are too thick and you can't focus the beam properly.
