where to buy plastic Caps for C8 Pills
Hi!
I want to use this C8 copper pill *on a uniquefire T20
But I can’t find the Plastic cap that Holds the LED MCPCB in place
Do you know where to buy it?
Thanks
1. It is brass, not copper
2. This cap dont hold mcpcb in place. It helps to avoid reflector short-circuis
3. For zoom light you need black one.
for a reflector light you need a centering ring or gasket matching the reflector hole and the LED size
http://www.kaidomain.com/p/S026984.11mm-x-1mm-White-Plastic-Insulation-Gaskets-5pcs
the reflector pushes the MCPCB down of course you can add 2 threaded holes to hold the MCPCB and prevent it from rotating, which can cut in the wires
