Where to find XRE R2 LED's
Where can I buy XRE R2 LEDs? I have checked int. outdoor and they don’t even list them. I have difficulty navigating the Kaidomain sight. I put led in the search box and click the search button and it does nothing. Any help would be appreciated.
Rick
Here
Here
DX has XRE emitters
Is there much of a noticeable difference between R2 and Q5?
I ask because LEDDNA has Q5 for $2.85 each, $2.57 if you can find that 10% code that's floating around.
http://www.leddna.com/xre/
This is were I get my XRE-R2s they are the brightest ones I have found. They pull 2.8 amps on direct drive. They are really fast shipping also around two weeks tops.
Thanks everyone. Erik which driver would you suggest. I want them for my Jacob A60. It pulls about 1.9A on a good Eagletac 18650 2500 with the stock emitter and driver. It is an awesome thrower now but I want to push it over the top.
You could just use the stock driver 1.9amps will push it along fine or if you want to max it out a Nanjg 105c is what I use, it will feed it the full 2.8 amps it wants.
If you want one fast go with Shiningbeam, Illumination Supply only has the 3 amp ones it’s a little to much for this XRE
http://www.shiningbeam.com/servlet/the-132/3-dsh-Mode-Regulated-Circuit-Board/Detail
If you don’t mind waiting DX has them cheaper or I can send you one if you want.
http://dx.com/p/17mm-2800ma-5-mode-regulated-led-driver-circuit-board-for-flashlight-diy-dc-3-4-5v-127684?rt=1&p=2&m=3&r=2&k=1&t=1&s=106796&u=127684
Do you think if I used the stock driver with an imr it would push it to the 2.8 amp max? I put an aw imr in and it pulled 2.4 with stock emitter.
It’s probably a direct drive on high driver so it probably would deliver close to max with an IMR. Give it a try you have nothing to lose.
Thanks. I will try it as soon as my emitter comes in.
Whats a good source for an XRE-R2 P60 drop-in that pulls decently?
I had this single mode Q5 and R2 before I started making my own.
This is the brightest stock XRE drop in I have found. The single mode Ultrafire Q5 drop in is much brighter than the single mode R2 because it has a better driver, but it’s a little more expensive also.
http://www.manafont.com/product_info.php/ultrafire-cree-q5-mode-led-dropin-module-36v-84v-p-4053
Here is the R2 I had, the Ultrafire Q5 blows it away
http://www.manafont.com/product_info.php/generic-cree-r2-mode-led-dropin-module-318v-p-9132
Here are some other I haven’t tested.
http://www.manafont.com/product_info.php/ultrafire-cree-q5-5mode-memory-led-dropin-module-36v-84v-p-4054
http://www.manafont.com/product_info.php/cree-r2-5mode-memory-led-dropin-module-342v-p-6095
http://www.manafont.com/product_info.php/generic-cree-q5-3mode-led-dropin-module-3742v-p-6096
