Where to solder on SRK board?
Got a driver: http://wallbuys.com/Product/3-7-4-2V-3-Mode-CREE-T6-Driver-for-SkyRay-King-3T6-LED-Flashlight-Golden-Black-46-2mm—10684
Inductor shares with some spots and not others… Too scared to do trial error yet.
I think it goes like this:
On the top:
I know the SMD switch goes on K1,K2.
But, What is the N2 for?
I hope you guys can help me out (: Thank you!!!
Any way I can resistor mod this or something?
K1 is the one closest to the ground ring (should test as ground with ohmmeter), the other switch pad is K2. N2 is between the two switch pads and not used.
There are 3 sets of sense resistors, one set for each channel. Just bridge across each set with copper sheet or wire. It'll run at about 4A per channel on the very hottest cells, the FETs used (AO4468) are not that great and keep the current undercontrol all on their own without the resistors.
Thanks for the top on the SMD switch. I didnt know the middle was N. Everything works now (:
