Which 18650 advised for Convoy C8 light?
Hello,
I just received my Xtar VP2 charger and need to buy a few 18650 batteries.
I usually buy all my eneloops and other batteries from Nkon in the netherlands as that is practically around the corner from me. However I noticed with all unprotected 18650 batteries the Nkon website advised to NOT use these in flash lights.
So now I only have the choice of ordering EagleTac, EnerPower and KeepPower batteries (all Samsungs, LG and Panasonic 18650 batteries on the Nkon website are unprotected versions).
Is the warning on the Nkon website just being overly cautious telling customers not to use unprotected 18650 batteries in flash lights?
So, what do I buy? Can I use unprotected 18650 in the Convoy C8? Will protected 18650 even fit in the Convoy C8?
I can tell you that Convoys are tighter than a nun when it comes to protected cells. The EVVA 3400mAh cells that I got have to be forced in and the only way to get them out is remove the flashlight head and push them out.
I’m giving the grandson a C8 and charger for his birthday and I will only give him protected cells so he’s going to get a modified UltraFire instead of a Convoy. That is such a shame because the Convoy is so much nicer than a UltraFire.
There may be other protected cells out there that might fit a Convoy but I haven’t seen a list of what will fit. Maybe RMM could make a list of what protected cells fit?
With the single-cell light, you should be okay with unprotected, as long as you use common sense and don't drain your batteries down to nothing. I run unprotected cells in a lot of my single-cell lights. Single-cell lights are inherently safer than series-connected multi-cell lights.
I NOT use any “protected” in any flashlight.
At Nkon, you have the NCR18650BL (Sanyo)… it is great, better than the NCR18650B (Panasonic).
Sadly I don’t got a Convoy C8, yet. But I think that Soshine 3400 is among the smallest protected panny B you can find on the market.
Last post says 18.3 mm so it may fit in a Convoy C8.
NCR18650BL at Nkon
Test of NCR18650BL by HKJ
Thanks for the NCR suggestion, I have ordered two batteries, should receive them tuesday at the latest.
