I now think I have a better idea of what I want. I definitely want to try a 18650 (or maybe a CR123) light later but as I need a light pretty quickly, I am going to go for one powered by either 2x AA or 3-4x AAA. I plan to use Lithium primaries in it (like Energizer) but it would be good if it could use rechargeables for the future.
My key requirements are:
- 160-220 lumens output
- a wider beam that will light up more area is preferable to a narrow, focussed beam
- a few modes to play with would be good but not essential
- decent run time
- not longer than 6 inches
- Budget of approx. £50 (approx. $70)
I prefer a neutral light and still not quite sure of the difference between the XM-L and XP-G emitters.
I should have also said that the light will mainly be stored in the car (so fitting in a glovebox, hence max 6 inch size, would be good) and used as an every day torch for rural night walking or checking out the back yard (which is about 200 feet long)
What I have really come to like is the sunwayman v10 & v11. The v10 is cheaper but gives same output. Buy the AA adapter and you now have a light that runs all AA size and cr123/16340. Just a thought……fasttech has great price on them.
Regular AA /14500 size EO3 is great and the balder is a nice one for little money.
Don’t have this particular model, but I really like my V11A and V31A. Nice form. Good build. Simple modes and interface with fwd clicky.
Crelant used to have neutral tints in XML, but looks like they are not out yet for the new XML2 models. Can probably find an older one around if you really want neutral. Honestly, the difference between XML and XML2 is not that great.
XML is all flood. Big hot spot, some spill. XPG is more throwy relatively speaking, but not a pencil beam by any means. Tighter more defined hot spot than XML. Good useable spill. I am a really big fan of XPG and XPG2.
Both XML and XPG are available in a variety of similar tints. They just have different beams. Google image search some beamshots to see what I mean.
Thanks. I did read it and commented on that thread. Appreciate you making a review for us, but I honestly disagree on your overall opinion of the light - at least, based off the ones I have. Hope crelant is not going downhill.
Thanks for all the suggestions. Unfortunately I need to get one of these within 10 days and therefore cannot trust overseas delivery to get here in time. I did look through them to see if I could get them in the UK.
I cannot find the Xeno from a UK seller
The Sunwayman v10 and v11 are £60-£70 so outside my budget
Again, for this purchase, I need to order from a UK seller
Any thoughts on the ones I listed in my OP which are all available in the UK
Thanks Chloe. I have been browsing the Flashaholics store. Looks really good. I wasn't aware Heinnie were UK. I will look at them too.....once I know what I am buying ;)
Yes. XML is bigger floody type beam. Will not throw or reach as far as XPG (at similar power).
Eagletac is a very good brand.
Both XML and XPG can get the job done. Some people generalize XML is good for indoors and closer quarters, XPG better for larger area outdoor where you might need some throw. Maybe you should watch some video reviews on youtube. That would help give an idea the difference between the two more than pictures.
i would recommend http://www.torchdirect.co.uk/ i have bought from them several times, there service was excellent as where there responses to my email quires.
Heinnie Haynes is where i buy alot of my blades from there service and communications where excellent as well.
