Which flashlight could beat L6 in holding turbo?
Hi everyone,
For security work on open field we are looking for flashlight better than Convoy L6.
At the moment we think L6 is best choise because:
  • fits in price range;
  • has good throw and flood,actually we prefer better throw;
  • works 15 minutes on 4300 lumens;
  • has good grip and balance. Tube is not big as 4x18650.
    Can you suggest better options?
    Thanks.
Hard to beat an L6, especially for the price. I love the dual switch and it feels great in my hand. Maybe Simon has Osram or SBT90 or something coming with more throw.
Sofirn sf47 looks to be a good light. But it’s nowhere as bright. But has plenty of throw.
L2? Same form-factor, lots throwier.
Yeah my soda can light can hold brighter longer but it’s far floodier. Maybe the Sofirn SP70 can do slightly better?
We cheched it, but SP70 does not have stabilozation.
It is FET driver.
In theory, you could swap the FET driver in SP70 by Convoy‘s FX31 buckdriver (for the L6 model) and do a resistor mod for continuous output of 5-6A.
Just ask Simon to install Luminus SST-70 instead of XHP70.2. I modded my L6 with that LED and the throw increased A LOT and the beam quality is excellent.
isnt there a L6 with smooth reflector ? more throw then OP… i think hard beat this light since it can run until battery runs out more or less… got to watch temperature but should be ok in colder envirionments.
SST70 is equal to XHP50.2. In L6 driver on turbo will heat up quickly which we do not want.
I am thinking what is better for security work: L2 with XHP50.2 on 2000 lumens or L6 with XHP70.2 on 4200 lumens?
The SST-70 gives about the same amount of lumens as the XHP50.2 but with more throw. It has a smaller LES. Heat is only a little bit worse than the stock XHP70.2, but equal to the XHP50.2 which I had in my L6.
If you want to go for the L2, the SST-70 is still a better bet than the XHP50.2 IMO. Pulling less current with an LED with more throw is the way to go.
My convoy m21a(the c8+ with 21700 bat) and stock 6amp driver and xhp50.2 holds turbo extremly well. Not saying it coulsld replace a l6 but if you ever need something smaller with high turbo runtimes I would deffinelty recommend this light. My L6 runs 8 amps to dedomed xhp70.2 and smo reflector. Throw is nice because of the output but It sure would be more efficient with lower amp and smaller led with higher intensety.
You will need to pay x3 or DIY to get something better then L6
Thanks for this info. I have this m21a with driver but the cslpm1 Simon sells it with. But I have xhp50.2 on 20mm mcpcb coming in. Will try a swap to see it’s performance. Was also going to try a emitter Swap with my yootoo SD3 amutorch.
From sst40 to xhp50
You did order xhp50 3v right? just making sure. Im not sure the original gasket fits.
Output is very nice, not to throwy but still some reach.
I did. I put request in with Simon and he listed it on his AX store. Simon is on point with those requests, great seller.
I also ordered a whole slew of 10 packs of gaskets, so I am covered for most applications. Gaskets and some leds came in, but my small order with my xhp50’s are still in transit. Those small packages take forever. I have orders from Simon that I ordered after the xhp50 order come in before it. Ohwell. Soon I’ll have them. Ordered 3.
While SMO gives a bit more throw, the differences with OP are minimal, its just a few percent.
The XHP70 is more efficiënt than the XHP50, i’d advise the L6.
Its classic, but well built (its a tank) and very efficiënt, with a good driver and it has a tail and sideswitch.
Also, you can tweak its output by doing a resistor stack mod.
The Convoy L6 is one of those must have lights.
