Which flashlight to get?
Hi All!
Been reading the forum for sometime and decided to register an account today. I have been looking for a flashlight and is little overwhelmed by the wide variety of flashlights available and the terms used. :open_mouth:
Would like seek advice which light should I consider. Here is my criteria.
-Run on 1-2 AA/AAA batteries.
-Long runtime.
-Purpose is for reading in the dark for extended period of time. (read that a suitable lumen is around 3?)
-Below $50(lower the better :bigsmile: )
-Must have 3 modes at least (apart from use it to read in the dark, also for other purposes which need higher lumen)
Thanks!
Personally for reading I like a nice even light rather than one with a hot spot. There are several ways of doing this, but something with an aspheric set to flood works really really well.
Another option is something low powered that you can remove the head on. Either that or you might want to consider some kind of diffuser.
The little sk68 works brilliantly at this, although runtime on 1AA eneloop isn’t as good as some other lights.
Others I’d consider:
-LED MagLite Solitaire because you can take the head off
-LED Mini MagLite AAA, again because you can take the head off
-LED Mini MagLite Pro+ has a low mode and you can either take the head off or get an aspheric lens from somewhere like DX and offer up a nice even light with no hot spot (I run an incan Mini Mag converted to LED with one of these lenses and it’s brilliant for reading or close up work)
Some Led Lensers with thier TIR optic likely offer up a nice even light for such a task also.
Last up you might want to look at the little FourSevens Preon 0, 25 lumens but a real floody, not quite as even light as some of the above but pretty darn good.
CD, you mind sharing a link to that lens? Or at least which diameter lens is needed?
-Garry
Welcome to BLF, manussa.
I think Lighthound has the best selection for AA lights. Use code blf for a 2% discount.:
http://www.lighthound.com/EagleTac-D25A-Flashlight_p_3521.html
http://www.lighthound.com/EagleTac-D25A2-Mini-Flashlight_p_3948.html
http://www.lighthound.com/Lighthound-AA-Tactical-Flashlight-Cree-XML-T6-LED_p_3958.html
http://www.lighthound.com/Fenix-LD10-Cree-R5-LED-Digital-AA-flashlight-6-Levels_p_3784.html
Going Gear has some great 4Sevens clearance items right now:
http://goinggear.com/clearance/4sevens-quark-x-aa-cree-xm-l-led-flashlight.html
http://goinggear.com/clearance/4sevens-quark-aa2-turbo-cree-xp-g-r5-led-flashlight.html
Shiningbeam has some nice AA lights as well. Code BLFUSER will get you 6% off:
http://www.shiningbeam.com/servlet/the-108/**NEW**-Olight-I2-EOS/Detail
http://www.shiningbeam.com/servlet/the-30/ShiningBeam-Caveman-Cree-XM-dsh-L/Detail
http://www.shiningbeam.com/servlet/the-76/ShiningBeam-Spark-XP-dsh-G-Neutral/Detail
I say get the Balder SE-1, but get it at EDC Plus where you can get it in Neutral White (more realistic color rendering). Go ahead and get the extension tube so you can run 2AA if you ever want to. I don't own it (but want one). Nice 3 modes with a low low and no blinkies. Very highly regarded around here.
-Garry
Garry:
I thought about the SE-1, but I can't find lumens output for the Medium and Low modes anywhere. Do you know for sure what they are?
@garrybunk
I’ll try and find the SKU or a link out for you.
I don't know for sure, but I'm betting it's the same ratio as the Lighthound version (which is really just a Balder rebranded as far as I know) which is 100% - 30% - 1%. Not much info I'm finding searching BLF, but you could compare with how2's review and currents. Those currents pretty much confirm the same ratio as Lighthound. The low is definitely very low (+/-1 lumen? )
-Garry
Uniquefire UF2100 …… E-Tomic E1320 5 mode with firefly mode….
This is the one I used:
http://dx.com/p/22mm-5-5mm-30-60-degree-99-transmittance-glass-optic-13570
The bezel doesn’t quite screw on all the way but it fits on well enough or you could trim the lens down a little if you wanted to spend the time.
It also won’t let you “zoom” like an sk68 as to focus the LED you have to just unscrew the head off. But in “flood” mode it offers up a lovely huge even lit area with no hot spot. I find this hugely useful for close up work and using round the house.
Sometimes you’re better off with two tools to do two jobs, rather than one multipurpose tool. A reading light like this one would be suitable, then get a torch to do what you’d like.
For reading at night on my balcony I have been using the Balder SE-1 (neutral) running on eneloop with an inexpensive diffuser I got at Intl-outdoor.
Oh, man, I was going to recommend the 4sevens from Going Gear because for that price they are hard to beat, but BetweenRides beat me too it! Well, welcome to BLF, Manussa.
Thanks! I'm not looking to "zoom" with it. Just thought about making a light with a nice even flood and if it's a Mag mod even better.
-Garry
:party:
Do what he said! >) >) >)
The very best advise!
My 1ST wife and 9 yearold granddaughter use the book lights for hours before they fall fast asleep. then what ever else you need!
i prefer TrustFire X8 Cree XM-L T6 LED Flashlight from Ankaka.
