Which FW3a LED did I get this time?
Thanks guys.
Now comes the hard part - deciding on my path.
- return/replace and be done with it?
- some store credit, keep the wrong light, and maybe try to put the right LED board in it.
  • keep the wrong light and take a deeper discount on a Ti/Cu hybrid…
Besides the lower CRI, what are the practical differences between the 5k XPL-HI and the 291C / SST 20?
XPL-HI puts out more lumens
Both in 5000k? Xpl-hi has higher output/efficiency, better tint and runs cooler.
The MCPCB is held in by pressure from the optic, but current FW3As have a set screw to prevent it from rotating while the bezel is screwed down. You would either have to drill out a small hole to accommodate it or remove the set screw itself, which I believe is threaded in from behind under the driver.
Lower CRI, less heat, a bit more output, also more expensive.
Hmmm… Nothing like a simple problem. Get a heck of a deal on a light I don’t particularly want, but maybe I should want, because if runs brighter and cooler…
