which led/drop in for a Cofly KX-D011?
Hi all, I’m a really newbie in the wordl of modding, so I’m trying to find more info I can to try to put more lumens in this Fenix clone :wink:
The original led is a XP-E R2, that the link of the flashlight : Cofly 2aa
Can I put a better led in this little clone? If yes, what do you suggest?
Thank you all and sorry for my bad english…:frowning:
I would personally leave that light as-is. The smaller XP-E will give you a tighter throw than a larger-die emitter, with more surface brightness. An XP-G2 maybe (?) but that would likely be less throwy and and a worse performer. Depending on that light, a better driver might be the best modding option to boost output but the light may have to many limitations. You are limited by using 2x AA cells, and if heat transfer is poor, driving too hard might be bad...
If you want to break into modding, look into a nice P60 where you can get interchangable parts with standard sizes. Wink
First at all, thank you very much for answer me :slight_smile:
Now I’ll find some info for XP-G2, seems to be a nice idea!
yes, that can be a solution! Infact I’ve read on wiki that this XP-E can go till 1000mA, and the range of lumen is 251-268! Now, it drive at 700mA, so the range it’s 194-207 (for XP-E R2). It is right? 250 lm will be the best mod for me, sure :bigsmile:
yes, only 2xAA, but what if I put 1x14500 + ! dummy AA cell? I don’t know which is the input range of XP-G2, sorry…
yes, that’s a real problem… :~
thanks for suggestion! I’ve read a lot about P60! But I really like this clone, and will buy it if can improve it… :wink:
Any other suggestions? 0:)
I really like this clone…but don’t know how to do…to be in right way, I mean…
Thank you!! :smiley:
I like the COFLY KX-H10 Cree XP-E R2 (a 1-AA zoomy recommended over in testing a red XP-E, and comparing it to a red XR-C, 22/4/'14: XP-E2 results added in post #32 - Flashlight Modding and DIY Parts - BudgetLightForum.com as a host for color emitters) — but it has a thin, tiny ledge that the emitter sits on (with no thermal goo, so the emitter really is only held in contact around the edge by the pressure of a little plastic donut disk pushed down over it). I’d bet the 2xAA light is the same, but you have to get it and open it up.
So for a start I just did as that topic describes, desoldered the two wires from the old emitter, soldered the same wires to a new emitter, and added a little trace of thermal goop. Pushed the plastic thing down over it and it works. I wasn’t aiming for hotter and brighter though. Just saying, these lights are cheap, emitters are cheap, get a bit of thermal goop and see how hot it gets.
(This one has a high/medium/strobe driver; on medium it can be left on a while without getting noticeably warm)
