and the site they are selling them.
Also….looking to find a p60 drop in with one in it, will it work with a 18650 batt?
Sorry if this thread is already out there.
L3 illumination L10 from sbflashlights is probably cheapest light available with the 92 CRI nichia 219 (not all 219s are high CRI)
EDC+ has exclusive Xeno F7 (18650) and E03 (14500) stock with 219s. They have a triple 219 p60 drop-in that is sick too.
I believe the new high CRI Peak brand lights use nichia 219s now… they are not very budget, but made in the USA.
I believe that this is one of the best Nichia 219 lights out there. A deep smooth reflector with an immaculate beam profile. An 18650 torch with high quality machining and anodizing. This Light outthrows any Nichia I own, and I have quite a few. I cannot believe that these have not been all snapped up for $39.
Xeno F7
I like my nichia F7 a lot too
purchased partly due to your input.
Curious… What other nichias do you have to compare it to?
and using an 18650 this light puts out about 200 lumens ?
Yup, Believe the modes are 200 / 90 / 8 lumen according to Xeno. Nichia 219s don’t take a ton of current like XMLs… This does make for long runtime though.
what is the most lumens the 219 will put out in an 1 - aa light with eneloops?
Around 100 OTF I’d say.
But an AA light with a 14500 and a proper driver is a whole new ball game.
Here’s a Nichia 219 Drop in for P60 hosts $35 (for single Li-ion 3.7v battery): P60 / Nichia NVSL219 4500k 92 CRI
And another one (a triple and expensive, also for single Li-ion 3.7v battery): Triple Nichia 219 Neutral White LED P60 Dropin
I ordered that P60 from them, but wasn’t paying attention, and ordered the one with a smooth reflector by mistake. It has to be the ugliest, ringiest beam profile I have ever had. I removed and changed the reflector to OP, and now its OK. Basically, you can build the same dropin for about $12.
of course I want the triple but even the single is too expensive - dang
Might be time to give it a try Rix
I’d be interested in the $12 p60 build, can you post any links to a build thread or parts?
EDIT:
I found this thread: My Solarforce L2N + Nichia 219 project with links to about $12 in parts, thanks for the idea.
I put one in a Thrunite Saber. It puts out 90 lumens on an alkaline. None of my Nimhs fit in the tube.
Anything you need to know, just ask. We can guide you you.
Thanks, for the driver from fasttech you linked, at 1400mA I assume it’s ready to go for Nichia219 use? (in the build thread by Uldzha that I linked he removed 4 chips from the nanjg 105 Driver to bring it down to 1520mA, that’s where it got a little sketchy for me to attempt)
Also do you know of any Nichia219 available already on a 16mm MPCB or would it have to be reflowed onto one?
Have you tried building one of these yet?
any budget lights have the Nichia ?
I haven’t found any mounted on 16mm MPCBs. I just reflow to the size I want.
Bare Nichia 219
16mm MPCB
If you have never built a light, a P60 is a good way learn.
