I have an old Fenix TK-35 (2010) with the original XM-L T6. I want to replace the led with something more modern but my abilities to mod stuff are pretty basic. I can solder and add some thermal paste, but I don’t have a lathe to create a new base for the led. I also don’t want to use a new driver, so I need some led with the same voltage.
I know the XM-L T6 is 3V, so I’m thinking to replace it with a SST-40 4000K, which is the same voltage, and the die is apparently similar too. (is this correct? is there any better led for this matter?).
Also, the original driver has an output of 2.85A. The only source for modding this light I can find is this post, where they soldered an extra resistor to increase the output to 3.8A. I will probably also do this. How can I increase the Amperage a bit more more (I am thinking closer to 6A)?
The flashlight uses 2x18650 in parallel, I’m using Samsung 30q which have 3000mAh (which is already 50% more capacity than they used to be a decade ago), and they have a max continuous output of 15A each, so they will be more than comfortable with any increase in power. Also, the light is a big chunk of solid aluminum, so it will be ok.
