Not minding the sellers, i want durability and constant current and constant voltage ability (doesn’t have to be both at the same time but bonus if it can be)
I want to be able to power LEDs, use it as a makeshift power supply when i need to use something for a few hours but lost its power brick, and use it for current testing on drivers.
That’s an easy one. The one from banggood fits your requirements best. Digital display, the other would require a DMM or the like to check the volts/amps. Buttons for adjustments, other requires screwdriver. 10 memory storage other has none. It is larger but soo much more versatile.
I’d take the one from BG for your purpose, as it has a display, so you don’t need an extra mm to measure voltage/current and it has buttons to adjust everything and is meant to do what you want to do. The other one is meant to charge batteries, which you don’t want to do. Also the little pots are no good to adjust very often.
Can you actually use the BG thing to charge batteries in CC/CV mode with adjustable voltage and measure battery capacity?
That would make a great and powerful budget charger!
