Which pistol grip lamp??
Hi there guys, I ’m looking for some help if anyone has any info?!
I’m looking for a lamp/spotlight that has a pistol grip.
I did purchase this but it’s not very bright and had a black spot in the centre:
I’ve been looking at one of these:
But then I came across this
I’d like something with a decent throw and I wasnt sure if the bigger reflector on the amazon lamp would mean it’d throw better or if the better led’s in the night-sabre would mean it’d thow better?!
Anyone have an opinion or know of any similar lights that might suit me better?
I do like the feature on the Night Sabre where you can swap the pistol grip out for a standard torch if required.
Thanks!
J
You could get a BLF Q8 and add a tripod handle like this reddit user did:
https://www.reddit.com/r/flashlight/comments/7qxnor/i_think_i_finally_figured_out_a_good_handle_for/
Or, you could get the Sportac ZP10L9 , but it needs an external battery pack.
Thanks bmengineer, the Sportac is a bit out of my price range, the BLF Q8 could work but I’m guessing it wouldnt have an on/off switch to hand when using the pistol grip.
do you think the bigger reflector on the amazon lamp would mean it throws further than the Sabre alpha or is this more to do with lumens?
Throw is based on a number of things, mainly reflector size and emitter size. I think the newer emitter in the sabre would likely compensate for the smaller reflector, but don’t quote me on that.
