I’ve been having these (evil) thoughts of making my modding life easier. My brother took his drill press from the workshop (our work) which has left me with only a 2 slide milling table with no drill :_(
I have gotten by without a lathe before as well, it’s not that fun in retrospect.
So I’ve been looking around and come across Seig which make small lathes available for cheap on ebay. Though I’m not really sure if I should get the smallest/cheapest or something one step up? For my intended purposes any of these lathes would probably do, I guess. Modding/making lights is the main reason for wanting one but I’m sure I could come up with other uses. Having threading gears is probably my priority. I don’t really know what else I might want. I was thinking I could get a drill/lathe combo but then though I could add a bench drill to any lathe and get the benefits of a better lathe.
The Sieg C1 seems to be the cheapest and simplest. I think I might prefer a C2 or C3. I tried to do a bit of research and from what I can find they seem to be value for money, particularly if you work on them to tighten up tolerances. One of the points bought up was the initial outlay for what’s needed to get started. This Real Bull seems pricey in comparison but comes with a number of accessories. I don’t know if I would use all those accessories but I might find they are really handy if I start using them??
So what do you think I should do, buy the basic and build upon it with what I want or get something that has a few bells and whistles already (as far as cheapy’s)? Or, of course, I could keep doing it the hard way :bigsmile: I guess one more thing to add is I’ll not be spending lots of time on it as I’m generally busy.
I would really like one with 1” to 1.5” diameter capacity and maybe a 12” bed. I really want one that can cut threads. I would mainly work with aluminum and copper, but could maybe need to make a pin or something for firearms that I own. My research kinda leaves me wanting more in a small machine.
Just throwing it out there - I saw these mini lathes in Japan. I believe they’re Japanese made. 株式会社東洋アソシエイツ|旋盤 . Quality looked excellent. They’re 100v though so you would need a transformer… after you managed to import one somehow.
As you would know in your search for one, there aren’t many companies making mini lathes. From online opinions you’ll find that the Sieg minis need servicing before you even start using them. How valid that is I’m not sure. But don’t expect to buy one and have it working perfectly on day one. Also, budget for tooling as well.
Buy the best thing you can afford. Expect to spend as much or more on tooling as the machine. Whatever you get (unless you go way bigger and more accurate than you’re looking now) you’ll be itching to upgrade within a few years. I’d look around for something used in the 10”x20” range if you can find one in good shape, it really is a huge step up from a 5”x10” in rigidity, and still a huge step down from something like a 14”x40”. A decent 10x20 class lathe will run you around $1000-2000 depending on the included accessories. The more that come with the machine, the better.
Whatever you do, if you buy a used machine, make sure you can check it out under power. Ask the sell to do some test cuts and threading to make sure everything sounds and runs OK. A great idea is taking an experienced machinist with you to check it out for you.
Good luck, I’m at the itchy to upgrade stage right now, it’s an addictive hobby/job.
I forgot to mention, most combo (lathe/mill) machines are terrible. I’ve seen a couple of good versions, but they’re few and faaaaaaaaaaaar between.
Don’t let me scare you off the 5x10 if that’s all you can find/afford. Just make sure you buy materials as close to the finished size as possible, even in aluminum it’s very time consuming to remove moderate to large amounts of material with a machine that small. Hell, it’s time consuming even with my mediocre 80’s era Taiwanese Enco 10x20, although I’m pretty conscious of the time things take. A hobby user who doesn’t have a “time is money” awareness may not care.
Ok thanks for the advice. I narrowed it down to this I can afford bigger but I’m having a hard time weighing up the price and how much I’m likely to use it. I got the 350mm version from ozmestore1 (ebay) for AU$850 (delivered). It doesn’t have much in the way of accessories/tools but that’s fine because that way I’ll build up on tools that I’ll actually want/use. In a one or two months work will slow down a little so I hope to spend a bit of time on it then H)
I’ve been surprised at how much more usefull my lathe (BV20 L) has been compared to what it’s intended use was, saved me a lot of trips to the hardware store, solved a lot of problems around the house and helped me keep my vehicules(tractor , motorcycle , car etc…) working in a pinch, and you’re the one that saves the day for the neighbour or relative for the odd repair job or engineering project.
It’s a very usefull, elegant, easy to use and satisfying tool, i just wish i bought a bigger one, i’ll probably do that when my shop is finished
It’ll get your feet wet, and teach you how to run a lathe. If you don’t already own an 8” bench grinder or belt sander you’ll want to pick one up for grinding your own cutting tools from HSS blanks. Speeds, feeds, depth of cut, and small nose radii on your tools will all be very important to getting the most out of a small machine. I recommend picking up a Machinists Handbook and learning how to look up and calculate recommended feeds and speeds for the material you’ll be cutting.
The spindle bore is also worth keeping in mind. I've also bought cheap carbide tools on ebay which are not to bad. The shop is in Victoria. Not overseas. I'll send you a link in a few weeks if you want.
Thanks MRsDNF, I did see that shop in my search. I’d appreciate the link when you have time. Always good to know where to get more tools… more…. MORE Muahaha
Sorry
Anyhow, the lathe I ordered arrived on Wednesday, nicely packed in a wooden crate.
I was expecting to work today (Saturday) but had the day off. Soo as a good flashaholic I got up early and went to my work where I temporarily set up the new lathe and read some of the instructions (mainly instructions for unpacking and first run). I did a small test piece to familiarize myself and then got stuck into it.
I made myself a pill for an FM26650 light with DX sst-90 reflector and head from 109 led showerhead flashlight. The light still needs some finishing touches but I got most of it done.
I also cut those aweful nobs off the UF-1504. I had thought about putting fins in as others have done but I haven’t got myself a parting tool yet as well as fins at that point will do little for the led on this light. Feels much better in the hand. The pill is fitted with an xpg-2 and LD-1 driver.
Absolutely lovin’ the lathe.
I got motivated to look over some other lights today. I sprayed some clear in the reflector of my supfire L5 to smooth out the beam a little. I also did the same for this lght . That dive light is a new fav. It is smaller and the magnetic switch starts at a lower low than this light
Maybe I’ll get some time next week to play with the lathe again.
