why am i starting to like DIRT cheap lights more?
A good solid host ... an emitter and driver swap .
They perform marvelously, can take abuse and still cheap enough to use without worrying about loss or damage.
My bare A6 is my current edc and its already proven the value of its unclad nature. Even good anodizing gets beat up and although this one is obviously scratched and dinged it’s all the same color. For me there’s a minimum standard of quality but it’s not based on a name but on the basics of switch quality, fit(including the pill), and anodizing. It seems most of the really cheap lights fail in switch quality or the fit of the pill and both of these lead to intermittent operation and lots of wacking the light. The BLF Ti is pretty but the switch itself and not being able to produce a switch retaining ring that fits dropped it into this category. Granted, it’s very inexpensive for a Ti light but these two things turned a budget Ti into a cheap Ti. Hopefully his successive efforts have not suffered from things like this.
I like dirt-cheap lights too!
I don’t use unmodded dirt-cheap lights though. And they tend not to be dirt-cheap after I’ve finished modding them.
Currently EDC’ing a clone Sipik 58 zoomie, modded with LED Lenser style lens, FET driver, and 5000K XPL HI 3D emitter. I’m contemplating what additional mods to make to this light. Considering the following:
  • Bore out body tube and add conductive sleeve. Upgrade driver. Rebuild tailcap internals to support e-switch.
  • Bore out body tube for Efest 16500.
  • Remove some or all of the anodizing and polish bare aluminum.
  • Add copper around bezel for decoration.
  • Swap 3D emitter to 5A2 tint.
Biggest concern with boring out the body tube is the o-ring slot for the sliding bezel is in the tube and is very deep. If I bore too far I might hit this and destroy the tube. Would be much better if that slot was on the pill. I think actual SK58s had a shallower slot and used smaller o-rings. I’ve ordered a few more SK58 clones. Not sure if actual SK58s are available anywhere anymore.
It’s hard to beat the SK68 clones that are under $2 postage paid on eBay (search for Cree Zoom) (and yes, they’re not Crees)
I tell people who ask me how to get a better flashlight (starting from a 2D incandescent) to buy five or six, each from a different seller to spread the risk.
Total expense under $10 or $12, and they can work up from there once they get used to them.
I generally use my BLF 348s inside with their simple UI and beautiful tint and I use my hotrod lights outside. Maybe I’m too young, but I can’t stand the XPE blue tint.
I don’t see why you’d waste money on expensive lights if you weren’t going to use them.
Flashaholism does seem to lead to the occasional irrational purchase or deed. I don’t need my Cu/SS X6/X5 set and probably won’t use them much if at all but they sure are nice to look at.
I find my most commonly used lights now are the Astrolux A01 and BLF-348. Mostly because they have really nice tint, but they happen to also be inexpensive. I use my more expensive lights for tasks that require more output or longer run-time (such as outdoors).
The thing I can’t stand about most cheap lights is the horrible, extremely cold, cool-white tint. But for those people that don’t care about tint, they can make decent lights.
How do you find these?
(I don’t mean “they’re very nice” I mean omfg they exist WHERE??
because I’ve been looking for my second SK58 for a very long time)
Here.
:wink:
Looks like everyone is out of stock. :person_facepalming:
Isn’t SK58 not just a typo meaning SK68?
And talking about real budget lights
when I got the Olights in I ordered a small cheap light to use the extra 16340 cell in and to compare the Olight with.
This thing is so much fun, I gt a silver one.
It does not work with 16340 cells but the CR123Rechargeable Olight cell works just fine
thetintiscold,sameas the Olights, it is almost as bright as the Olights on high and in low mode between the Olights low and med.
It becoms warmer much faster then the Olights.The pill can be removed and I am going to put aNichia 219B in there i think.
The SK58 is not the SK68. Same manufacturer, similar on the inside but a nicely textured simple tube light on the outside, mods the same way the SK68 does, same 15mm driver, solid pill (at least the one I found)
It doesn’t tear up your pockets if you carry it. I only got one before they disappeared and have been looking for more to mod as giveaways.
Yup. I love SK58s. Way better than the pocket-shredding SK68.
Found a couple different SK58 clones at DX this week. However, it seems nobody has the authentic Sipik brand Sipik 58 anymore.
funny you mention that.
i do the same with a srk.
except i knock down the offending critter or trap on a window.then set light on it and wait for the angry buzzing to stop.
a 3000 lumen light will roast a wasp fast.
as for the attraction to extra cheap lights its between modding and the semi disposable nature of them.where the laptop pull inside might be the most valuable part.
and since they are free its no loss if the light goes overboard,comes out of my pocket in the woods on a quad,or the same on i-70 at 100+ on my old kz1000 drag bike.
