Does natural gas produce so little CO2 that it doesn’t matter? I’ve never found out why we are able to use our natural gas home heating systems without asphyxiating from high levels of CO2.
I'm pretty sure there are vents that carry the CO2 and other gasses out of the house. The reason people need Carbon Monoxide alarms is for when those break.
Interesting, here the formula for burning natural gas is.
CH4 + 2O2->CO2 + 2H2O
So there is actually more water (H2O) being produced than CO2. Also the denisty of CO2 is 1.98 kg/m3 while Nitrogen (air is made up of approximately 80% nitrogen) is 1.251 kg/m3 so it would sink. Maybe that prevents any poisoning. I'm not quite sure though.
I thought that we had to beware of carbon-monoxide … We have a carbon-monoxide monitor fitted , plus those other smoke detector things that wake you up in the middle of the night “bleeping” when their battery gets low … Why do smoke detectors always seem to have bleeping low-battery warnings only at night ?
Also are waiters and waitresses specially trained to ask how your meal is , only when you have a mouth full of food ?
There are so many things that we don’t understand !
Carbon Monoxide is more dangerous than Carbon Dioxide. Carbon Monoxide, CO, wants to join with oxygen to become stable Carbon Dioxide, CO2. The reason it is so dangerous to us is that once we breath it in, it will combine with the oxygen that is already in our blood.
CO is formed from Incomplete combustion of fuels. Natural gas is not as likely to create CO as it burns.
having said that, my real worry right now is Hurricane Sandy and all of the Di-Hydrogen Monoxide that it will bring with it.
That’s highly unlikely…look closely and you’ll find that common gas fired furnaces have a closed heating unit (combustion chamber) that is inside the ventilation chamber. The cold air return is pulled in by the fan and pushed past and around the heating unit which warms the air and continues to push the heated air throughout the home using the ventilation ducts. The combustion chamber always has an exhaust vent to the outside of the building where hot and noxious gases are released. Many older homes simply use the air in the room or basement area to supply combustion air to the chamber, but newer homes often have a fresh air vent to draw from outside the building for the combustion chamber, and then vent the exhaust back out. Gas fired hot water tanks are similar in design and vent to the outside.
The problem with burning natural gas when there is not enough oxygen (Poor airflow or in a confined space) is that the gas does not completely burn (does not fully oxidize) and the resulting chemical reaction is:
CH4 + O2 -> CO + 2H2O
Instead of 2 molecules of oxygen only one is available and instead of carbon dioxide forming, carbon monoxide is formed
Actually, it has nothing to do with combining with the oxygen in your blood — if it reacted that easily with O2, it would do so in the air long before it could accumulate for you to breathe! The problem is that CO quite literally causes you to asphyxiate from lack of oxygen even if there is plenty of oxygen in the air you breathe, because like oxygen it binds to the hemoglobin in your blood, but unlike oxygen doesn’t un-bind when the blood reaches your cells. So each molecule of CO you breathe in reduces your blood’s oxygen-carrying capacity by one molecule of O2. (It’s not quite permanent, but it does take hours for half the CO to un-bind, so even a fairly low concentration in the air builds up to deadly levels in the blood stream.)
My 1967 1500cc Volkswagen Beetle had a heater like that … It had a metal jacket outside the silencer and air was pushed through the gap between them and that heated the car … I suppose that if the car occupants started to turn blue , it was time to change the (defective) silencer !
