Why is my oscilloscope doing this?
I have a used 100Mhz Tektronics scope (Model 2235A) with a Chinese 100Mhz probe. I have never used a scope before this one. The trigger level knob for the A channel was broken when I got it, so I use the B channel.
I can generally get it to show me a decent picture now, I’ve done enough fiddling and reading to get that far. A lot of the time when I get the scales set correctly to see something the waveform seems to scroll horizontally. It will speed up, then slow down, go left or right, then the other direction. In between I can sometimes get a decent look at the waveform, but so far I can’t get it to stay put or even slow down.
Thanks for any help.
It’s been a long while since I’ve used my oscilloscope, but I think that you need to adjust the trigger level on that B channel. That sets when the scope will start a new sweep I think, so assuming that you have a signal that is repetitive, if you get the trigger set correctly, you’ll see a steady picture/signal. If the signal is not repetitive, the picture/signal will keep moving all the time.
I’d have to actually try it again (it’ll come back, I’m sure) to be sure, but I think that’s it…
EDIT: The above is for an analog scope (probably like yours and mine). Digital scopes digitize the analog signal, then can store/capture signals, so you’d need something like that if you were trying to see non-repetitive signals.
On my USB scope, it does that if I disable the trigger and have it just plain display whatever's going on without aligning it with the center of the graph. No idea if a traditional scope even has the same controls though.
When I used a digital scope, it acted mostly the same as the analogue ones I used long ago, with differences mostly the conventions of a different brand.
Yes, it sounds like it is triggering a its own rate, instead of at a voltage level. Fiddle with the level and look whether there are other controls of the triggering.
Thanks guys, before you all explained it I didn’t really cotton on to what the trigger level was doing. Now I understand it but I haven’t had the opportunity to try it yet. I will report back soon.
I have the same scope. I agree it sounds like a triggering issue. At the upper right is a section called B-Trigger. A button selects to trigger on either a rising or falling signal. A knob adjusts the sensitivity. You should be able to tinker with those controls to get a stable display.
Thanks for the help on this guys. The trigger knob on my scope was broken. Rather than repair it I picked up a new scope… problem solved, heh.
Dunno, sounds like you still don’t know how to use a scope.
Trigger knob not that hard to fix. Hopefully you passed it on to somebody that can put it to use.
What makes you say that? Knob is literally broken, it’s been broken the entire time I had the scope. There is another knob, labeled similarly (“B-Trigger” IIRC), which does not actually appear to do what I initially assumed it did… I assumed it was a separate trigger for Channel 2. Later when I went back and looked it hit me that “2” and “B” are not the same thing - hence why it would never trigger correctly with the input on Channel 2 and me twiddling the B-trigger knob.
It’s certainly a nice piece of equipment, but that by itself was not enough to motivate me to tear it down (CRT and all) and replace whatever broke in/around the pot… and then figure out what’s up with the calibration.
Its a knob, a pick or small screw driver might have worked fine to set a nominal value that could be used without changing again.
OTOH I didn’t notice that I was in the BLF forum when I posted, as opposed to a much snarkier tech forum open in other tabs. Most techy types would have no issue repairing or at the least reusing the other parts.
Fair enough! I agree, I really wanted to repair it. OTOH it had the potential for other as-yet-unnoticed problems (did the previous owner break the knob out of frustration? ;-)) and tons of limitations: it’s huge, it hasn’t been calibrated in eons, it only does one channel at a time or two interleaved channels, etc… and you’re right, I’d feel much better about that scope if I’d repaired the knob. At the end of the day though I have [hobby] work to do and limited knowledge [edit: eg I would not necessarily know if the repaired scope was operating 100% properly], so I decided that it made the most sense to upgrade to a trusted tool with more capabilities and a more compatible size with my living/work space.
Speaking of my living space, I still haven’t gotten rid of the 2235A. I’d love to give it to someone who wants to repair it. I should get around to listing it as a free item in BST or on Craigslist or something…
Pretty much every analog scope in the world works that way (either alternating sweeps between the channels or chopping between the channels during a triggered scan). Dual-beam scopes are very rare beasties and you are unlikely to ever see one…
Would you be willing to ship it to Syracuse, NY if I paid for the shipping and handling costs?
Gotcha. [edit: I’d love to see one of those fancy dual beam scopes. I think most of my needs are going to be covered with the DSO I picked up.]
Maybe I can do better than that for you. PM sent.
