Why no applications for Luminous SBT-70 yet?
There wasn’t much fanfare in the flashaholic world when the Luminous SBT-70 was announced*, but on the surface it seemed to answer many of the community prayers. High output, smallish (think it compares in size to the XLM) and ROUND…opening an as yet unexplored world - I thought.
Almost 10 months later, I can’t recall seeing a single light, even from a Nitecore, Olight, etc …
Not losing any sleep over it, but wondering why there is no buzz?
Lumens, drive/draw, reliability, size, heat sinking, not suited to portable usage?
*what I was told by a lighting architect, a strong upgrade to the SST-90
This is the only one I have seen
You do know the Olight SR95SUT uses it correct? I actually intend to get my SR90 modded soon with the SBT-70. I dedomed my SST-90 and got some gains - 144k up to 195k, but I want more. I’m pretty sure the SBT-70 should put me in the 250k range.
They are expensive though. In the $40-50 range. Might be why other manufacturers and modders haven’t played with them much yet.
Yes, you are right. I think ut stads for ultra thrower. Would like to see one of these in action
With it being a round emitter, it screams giant aspherical lens to me
I think Kevin at Lambda Lights was planning on putting an SBT-70 into one of his VPT3s but it doesn’t look like he’s got around to it yet.
Does mouser or digikey carry these, or other source — link please…
Even the post is flying pretty much under the radar, for what I would have thought was a pretty hot topic, unless it was covered somewhere else already?
My friend the commercial lighting architect was just overjoyed at the possibilities of the round beam as opposed to everything else - square! He called it a game changer.
And I was looking at Olights, but they were SR models on clearance at IS…was in more of a budget mode.
I’m confused, too.
but what I’m wondering - aside from that fact that it is round, why use it for anything.
840 to 1485 lumen at 10.5 Amps? so, nearly 40 watts.
That’s spread over 7mm^2.
http://www.mouser.com/catalog/specsheets/PDS-002014_Rev%200X_SBT-70%20Production%20Specification.pdf
Cree’s MT-G2 does that at ~12 watts? And half the cost…plus it can be purchased on a PCB instead of a PCB with a big ugly plug on one side.
I must be missing something………what am I missing?
Competing manufacturers, and the MTG2 is a very different beast, minimum voltage is 6.5 volts, there aren’t any drivers built for the mtg2 currently that fit in a standard flashlight.
The SBt70 only really shows its worth in a large reflector or maybe an aspheric lens. In a small light it’s useless compared to an XML2-U2
actually, I happen to have 5 MT-G2s sitting here.
measured Vf at 3A is ~ 6.25V
and as far as driver - Every multi-cell driver that I’ve tried works fine (total of 4 drivers so far, more on the way)
I’m just going by what I’ve been told by VinhNyugen, and he told me there optimized at 6.5 volts, he’s been direct driving them on two cells to get them to work.
I’m just going by what I’ve been testing myself :slight_smile:
these work
http://www.kaidomain.com/product/details.S006130
http://www.intl-outdoor.com/boostbuck-318v-triple-xml-circuit-board-p-542.html
http://www.intl-outdoor.com/xml-multicell-circuit-board-35a-ouput-55126v-p-543.html
http://www.intl-outdoor.com/xml-multicell-circuit-board-3a-55126v-p-361.html
I am getting the learned/educated opinions and such that I was curious about.
I know there are applications, maybe the flashlight thing, (especially w the high wattage need and not the highest lumen output) is not the best or most appropriate usage, but the Architect had mentioned that he was ‘told’ that a single new Luminous 70 would replace a 250w HID…so I thought, heck, someone has to be working on this…. could be something big. Or not.
And certainly Cree has the ability to counter with a comparable or better round emitter if that is truly a benefit in their marketplace as Luminous seems to think it will be. So not looking like a game changer except in certain circumstances - stage lighting?
And the round beam and intense center hot spot would optimize a thrower, I would think.
But, its all in the application isn’t it?!
definitely seems more suited to applications w/ mains power…
I don’t think we’ll see a single LED replace a 250W HID any time soon.
I normally think “American Lumens” are more reasonable than Chinese lumens, so I had hopes… but in this case you are certainly right, I think his decimal points are probably off a digit or two?
Since he makes a good living at this, certain that the Architect (as he calls himself) will certainly get it straight before he bids/designs a job!
ask him what he meant? I’m kind of curious.
certainly there is SOME reason that they started making this LED…
There’s a reason…
The round emitting SBT-70 is optimized for narrow beam circular optical architectures. It is intended for high brightness systems that require a compact, surface mount LED.
Applications:
Entertainment lighting
Portable lighting
Medical / Microscopy
It’s HIGHLY inefficient when compared to the latest offerings from CREE though.
PPtk
I stand corrected (but still skeptical 0:) )
“enabling customers to use a single LED to replace a 250W HID lamp.”
source:
http://www.mouser.com/new/luminusdevices/luminus-SBT70CBT140/
Right, so there it is.
More than I knew before, and clear to see that a professional in his field of commercial lighting is seeing this from different sources - and of course, he (and they all need to) needs to use his smarts to clear the smoke away from the reality.
And there is so much more to what I don’t know about why/what/how…there are such differences in application, efficiency, output, etc within the same engineering family like Cree or Luminous, even taking into account same generation of products.
Again, application trumps all.
All I could think of with this in a flashlight application was some sort of ballast system like HID uses to boost the current…but not my expertise to do anything other than idle pondering…
Sure there is more to this, still.
