Will a 3 pin UPDI flasher work with 4 flash pads?
I have the Wurkkos TS11. It has 4 flash pads. The only programmer I can find is 3 pins. Will it work with the TS11? If so, which 3 out of 4 pads do I flash?
If not, where can I get a UPDI flasher with 4 pins?
PS didn’t the TS11 originally come with 3 flashing pads??
My TS11 shown for reference:
This is the UPDI for reference: t.ly/sZ-z_
That is the TS11S with a simple firmware that cannot be updated.
Oh no! How and where do I get the version you can update??
Just buy the TS11 without “S”.
Again how and where? I bought from Wurkkos directly and there was no indication I was getting the"S" version
example
https://www.amazon.com/wurkkos-TS11-Flashlight-Rechargeable-Distance/dp/B0BN3GYKSM?th=1
Notice it says Andruil in the description… No “S”
TS11 on Wurkkos site
the one you bought is this TS11S,
Ok thank you
It appears I didn’t notice but bought the “s” version by mistake. I didn’t even know there was an S non programmable version. I wish Wurkkos website clearly stated it.
Sigh…
It does. In the title " Wurkkos TS11S 2000lm Mini Flashlight with Simple UI" and in the description “TS11S is a simple UI from TS11, with 2 Groups, stepped modes and ramping mode.”
Compare to the page for the TS11 - " Wurkkos TS11 2000LM Powerful Rechargeable EDC Flashlight SFT40 with RGB Auxiliary And Switch, Anduril 2.0, IP68" and “It uses 1*SFT40 LED and BLF Anduril 2.0 UI .”
I guess the answer is that one should always make sure they do the requisite research before buying anything…
Then, of course, read the product description carefully. Unless one is prepared to be disappointed.
I don’t think you can blame this one on the seller.
