I bought a cheap bike light/head light with two 18650 batteries from AI. The batteries are in parallell so output is < 4.2 V. With fully charged batteries, the light starts out very bright but gradually fizzles out on all levels as battery voltage drops. At 3.5 V, the light is not even half as bright.
What if I reconfingure the batteries to be in series? Will the driver fry? I know very little about these things so advice appreciated. Is the driver a buck driver and did the manufacturer include the wrong type of battery box? Or is it just direct driver that will make the LED go insanely bright with a serial setup…or will the driver go poof? Any input appreciated.
I realize the seller's figures about output and batteries are lies...as they mostly are for cheap lights like these:). It works OK for the purpose though, which is 1-2 hours of skiing, so I don't think it is a waste of money.
Almost certainly yes, drivers that can take a large range of voltages are not easy to make, and would not be in a cheap light.
Double the voltage will instantly kill it.
If you remove the driver and do direct drive to the LED then you might be able to not have the LED burn up since LEDs (with proper cooling) can usually handle higher voltages fine.
FWIW, the one and only review for that light was a 1 star. That buyer claimed the cells were crap; about 900 mAh. Seeing that they are labeled 4000 mAh I’d say they probably are crap.
FYI, IF you did wire in series and IF the driver did not blow the run time would be even shorter as when you double the voltage (series) you also halve the available amperage capacity.
Do you have any other 3.7 volts 18650 cells? Borrow from someone? Good cells would probably give good / better performance. Another thing to watch / be concerned about would be the cheapy charger it came with. Some of those do not do a very good job or regulating the charge and terminating the charge. But you can buy a quality charger.
Yes, it will fry, probably the led first, but the regulator chip may go too. A driver that uses two batteries in series will regulate the voltage down to led level, I’m not into electronics but when a high output led is driven, that usually involves a much bigger thoroid (the copper coil) than is present in the driver from the picture.
No, no other cells. But I do have a charger I know works. Don’t thimk it makes a difference though. Maybe I should order some Panasonics and see how that works? And get a better driver and some swithces at the same time, although I won’t be trying anything until March or something when I won’t be needing the light as much. How does that sound
Please replace those crap batteries and you should be much better off. Still won’t be all that great cause it’s a crappy light but at least it’ll last longer. Lol @ ‘WindFire’. I guess to most ‘Fire’ is still a good attention catching word that draws customers in, whereas some of us see it as a dead giveaway that the cell is crap. I definitely wouldn’t try 2 in series. If anything I would just try a single GOOD cell in the light and compare the run times with the 2 crappy cells in parallel. If they are similar then using 2 good cells should give you satisfactory performance for the light you have.
ActualIy I got a pair of Windsport, not Windfire. Big difference But I did order new Panasonic batteries, so soon I’ll find out what’s what.
But this morning I got 2 hours of skiing out the headlamp with more than sufficient visibility all the way at mid brightness level. Voltage for each cell is now at 3,65. I’m actually not unhappy with the purchase. And it’s a good modder as the LED is on a star easily accessible from the front while the rear holding the driver is equally accessible and quite cavernous as well. Eventually I might get to it with a new driver.
I'm going to give a slightly more optimistic answer. Yeah, if wasn't built for 2S there's a very decent chance something will fry. However, it sure does look like a buck driver: inductor, big diode, switch all in a row. So the main limitation is if that IC is made for high voltage or not. I'd bet it is actually. I mean it's a buck IC after all. Then the question is just can caps take the voltage and is there some other limiting element. Only one way to find out really.
However, it's a not a great buck anyway. Those components look pretty skimpy. That doesn't necessarily mean it's more likely to fry, just that it's pretty sure to not perform well.
There are two switches and I assume two circuits on the board. I should have mentioned. Apart from the high power LED star there is a ring of 10 low power LED:s around it for close area light. Could the inductor rather be part of a step-up circuit for that LED ring? I measure 15 volts across under load. I don’t know how these things work….
it looks like a couple fets and resistors are switching the high modes straight from the pack and maybe that inductor is chopping up the low modes. not sure why they would power the led ring in series but it’s possible. if you are worried the circuit was a mistake try checking the loaded voltage of the led to see how close to 3v it is. or assuming it’s a buck driver meant for a 2S configuration and they put in 2P by accident, and the IC is not smart enough to adapt so it runs at a set frequency no matter the input voltage, because it’s designed specifically for a certain voltage input rather than a wide range… I guess the output voltage at 2P would be important to check. if it’s already putting around 3v to the led, and it’s cheap, then it’s probably working like it was designed. increasing the voltage beyond a certain point could cause too much heat during the on times of the inductor or if it survived that, provide too much voltage to the led. if the circuit at 2P is not putting out the proper voltage to the main led then I’d you might as well try 2S anyway cause that circuit is trash then.
Good point about the two transistors in the back right. Not sure what that's about. If that's for certain modes, that setup could fry.
But that inductor is hooked right up a big input cap, a diode (the SS24) FET (the 7001) with another cap, and what seems likely to big a sense resistor behind the front blue wire. You could call that "chopping" but that's a typical formula for a buck regulator, which, yeah, basically chops input current and buffers output current.
Ok the way too technical response (why not?): A buck is either current or voltage controlled but same effect either way so long as the output load is the same. Increasing input voltage should not increase peak input (FET) current or average inductor or output current. You do get more time with the diode active and more heat there, but less heat in the fet. If the inductor is too small (highly likely) you get much more ripple, which depending how it's controlled and filtered could mean more peak current or could mean less average current. The total heat dissipated is likely to not be very different but depends on many details. And of course the input (edit: cap) might not be rated for the higher voltage.
Still though, plenty of places something could fry if not designed for higher voltage. I'm just saying there's a chance it won't.
