Will this driver work
Hi,
Will this driver work with this 16mm led. Its for a simple mod on a wf501 flashlight. I do not know much about the voltage and current on these …… how they work best together.
https://www.fasttech.com/products/0/10001683/1122302-8-amc7135-4-group-25-modes-led-flashlight-driver-c
http://www.aliexpress.com/item/Epileds-5050-XML-8W-UV-Purple-395NM-400NM-Led-Emitter-Lamp-Light-3-4-3-8V/32601849656.html?spm=2114.01010208.3.44.tpSvrb&ws_ab_test=searchweb201556_10,searchweb201602_1_10037_10017_507_10032_401,searchweb201603_1&btsid=b5221673-db57-42cc-8e1f-e734906108fe
Kind regards
Michael Larsen, Denmark
Hey mate from reading the specs it appears it will work fine! working voltage and current of the LED and driver both match. The driver is standard driver found in many flashlights using 7135s.
Thanks a lot :+1: :smiley:
