The USB stopped working so no keyboard, mouse or wireless
I had an old USB to ps2 adapter so I got the mouse to work but no net access or keyboard it says code 19 windows cannot start this hardware because its configuration information in the registry is incomplete or damaged
Anyone have this experience I had restarted the computer because the wireless kept kicking out of service it installed some update automatically and did not save a system restore point and the last one won’t revert Windows gave some error when I tried
USB keyboard and mouse work fine for bios and windows troubleshooting
However this s not quite suicide, other windows versions self destruct and require deletion and reinstallation which I may do for this if I have to
@scaru I tried to make two partitions so I could do that but windows insisted I could not have less then 3 so I gave up and went with one so I could get it installed
Except for the problem that you can’t use your USB ports, so there’s no way to get those registry/driver updaters on your computer. Maybe if you can burn them onto a CD or something?
I’ve been an on and off lurker for the last few months and never had anything to add until now. I’ve run into this a few times and its an easy fix.
Get into control panel.
Select Device Manager
Go down to the bottom and select the Universal Serial Bus Controllers
Start at the top and work your way down - right click and uninstall each one “Intel® ICH9 Family USB Universal Host Controller” . You’ll notice that after you uninstall one, a USB Root Hub will also disappear.
Complete all and make sure that none of the USB Controllers are working and shut down your computer and start it back up. The USB controllers will turn themselves back on on startup. If you still have this problem, try the whole process again. I’ve had to do it up to 3 times to turn them all off.
After uninstalling whatever you uninstall in computer management you don’t need to reboot. Left click on action at the top and left click on scan for hardware changes.
XP By now is actually really good. So what if I only can use 3gig of ram and can’t see drives bigger than 2TB. When I need more, I will go to Win7. That too, I understand is quite good.
I’m going to try wiping the SSD and reinstalling windows and see if it still does it, hopefully that will indicate if its a software or hardware problem
Before you do win8 reinstall, suggest you check out the computer manufacturer’s forum. Maybe there are discussions on problems like yours.
The hard disk of Dell computers usually has 3 partitions: Windows, Diagnostic utilities, Factory install disc image. You can access the Factory image only if you did not modify the hard disk partitions. Factory image is the easiest option to reinstall. HP may have similar setup. Read up on win8 reinstall.
