I set my folders to all the same view (like in XP) (list, view by type) but i want to be able to manually select thumbnails (or even automatically if the folder is all pictures) when i am viewing picture folders, and i can’t find such an option, can it be done?
Also when i open a folder on the desktop in XP it would open a partial screen folder with only the folder i clicked on open, but now i get explorer full screen with all the folders on he lift side, is there a way to go back to how it used to work?
For the first issue, I’m not sure what the difference between a thumbnail and an icon is, but you can change the sizes by holding down Ctrl and scrolling. Not sure about the second issue, I’m used to always seeing the navigation pane, haha.
All of my Windows 8 boxes preview the photos out of the box. You probably have an OEM install (which I blow out with my own copy the first day I get a prebuilt system) which deemed that setting the safest to use (lowest common denominator) or the system did something funny during install, maybe thinking you had a low-bandwidth internet connection or something.
On a new laptop, I re-install Windows before I even start using it. And now for machines that come installed with Windows 8, the CD Key is burned into the BIOS and when you re-install Windows, you don’t even need to dig up and type in that key—it’s totally painless and gets rid of all that bloatware that pre-installed systems come with these days.
its a retail copy, i built the computer myself, installing all the asus drivers is a headache figuring out which ones i need since they no longer just have one large installer that has everything
Hmm that’s interesting. I wonder what made it decide to set that setting at install time. Like I said, none of my copies do that and they are retail versions as well, though taken from our MSDN subscription.
Windows remembers the view you set to each individual folder. Set the data files folders to view ‘by detail’ and the photos to view ‘by large icons’.
Is there a universal way to set those folder views in one shot based on content? I don’t think so. You can universally set every folder to whatever view you want, but it’ll set every folder to that single view and won’t make any distinctions about folder content/file formats. Sounds like you should just be setting the folder views one-by-one by hand individually. That’s what I do. Windows aint psychic
