A project requires a wireless means of changing modes, and turning the led on and off.
Are there options for this out there for BlueTooth, or 443/886?
4sevens built some lights with bluetooth capability.
Gotta be an actual flashlight? Or just A Light?
Simple answer, gut a set of “fairy lights” or RGB striplights and use the remote and receiver to hacque together what you want (most have simple on/off + brightness).
Not so simple answer, grab some similar BT-controlled lights, and gut away. (BT-controlled lightbulb, nightlight, etc.)
Pain in the ass answer, roll yer own with an Arduoni or even a Pi0W.
(Wow, actually run Linux to turn an LED on/off…)
It doesn’t have to be a flashlight at all, just a means to have wireless.
The battery and the actual light (emitter/reflector) won’t be in one body for this project, so maybe a driver with eswitch can be moded to work.
So far the ‘hard route’ would be using a rfm69 chip with a pic, but this requires me to make the board, and use <0402 smd’s to get the remote to an acceptable size.
The ideal would be if there was something out there that one could just lego together.
Lupine got a remote for their lights as an example that uses bluetooth:
https://www.lupine-shop.com/en/accessoires-and-parts/remote-control/1561/2-way-switch-blika
Many of those fairy lights remotes uses ir, and it’s super unreliable.
Imagine going into programming mode with such a remote …
