Witch 18650
I’m in need of 3-4 18650 battery’s that’s rechargeable but not protected
I have 3 protected cells but it triggers my H6CC driver and does not work.
What brand should I go with and where to buy ?
The batteries trigger the H6CC? I'm guessing you mean the protection circuit on the batteries trips? What batteries do you have? Also what is your budget for these batteries?
That’s correct I got it backwards, the battery’s I have now are 3.7v ultrafire
Budget around $15+
Sounds like the batteries are the problem, how much is the H6CC drawing? I'm guessing around 5 amps for the XM-L? Either way I would suggest these for your budget, 20 dollars for 4 good well matched batteries.
http://www.fasttech.com/products/0/10001901/1136603-authentic-sanyo-ur18650fm-18650-2600mah-37v-rechar
I’m pushing it at 5.5 amps on my copper sinkpad and a inch thick copper pill
Ill try them and see if they help
And isn't that battery pack wired in parallel? So that means each cells is seeing less than 1.5 amps, so those batteries are really screwed up.
No I’m using a series battery holder, I think it was from the DRY flashlight
Yeah, +1 for those Sanyos, but check them before starting, I’ve seen someone complaining because on of those Sanyos was DOA :expressionless:
Well, the batteries still should not be tripping as the total amount drawn from each battery is roughly the same.
he may end up with Sabrina the teenage witch
Haha yea that’s what I thought scaru,but then I tried 3x14500 and the driver worked perfect
Lol, that is how you know those batteries are a POS.
They came from fasttech, the first order I placed with them when they had there sale going on
I picked up eight of them from FT, and they’re all good to go.
