If you are worried about safety, I would recommend ones that are thoroughly reviewed by trusted reviewers. I wouldn’t use those cheap chargers unless I really have to. There may be good ones out there, but I do not have skills to determine which one is decent.
I currently use Lii-600. I hear Vapcell S4+ is pretty good.
Before my current charger, I used Lii-500. I was happy with it until one of the springs broke.
Charging controllers got inexpensive and mostly reliable, with minimum number of external components. These chargers use the same parts that are usually found inside the flashlights we use. While they can fail, it’s not very likely. At least not more risky than any built-in charging. The more advanced chargers with programmable microcontrollers are more likely to contain software bugs.
Always go with a trusted brand name. You buy something of good quality and, if you take care of it, it’ll last you many many years giving you trouble free service. I make a point of never leaving chargers unattended. It’s just sensible. Especially because my chargers are exposed (no built-in cover).
Search around and you’ll find a number of recommended brands, like XTAR, Nitecore, Opus, Folomov, KeepPower… I got a Fenix 2-bay charger that I really like (the ARE-D2), because it has all of the features I wanted in a nice small form factor. The ARE-D2 is excellent (despite being Micro USB) and while listing at $26, you can sometimes get it closer to $20 on sale. One nice feature is that when not plugged in, if you insert a battery it’ll tell you the charge level (using just a tiny bit of power from the battery).
I alredy contact the local support, they were not a help. Most points were unanswered, and telling me it´s a good charger because it decides how fast to charge. IMHO a manual selection is worthless if the charger override your selection.
